Hi all,
I am hoping someone can assist guiding me on what is possible to recover data on the below drive:
WDS100T3B0A
WD Blue SA510
The data on the drive is not very critical to me but would save me about 8 hours of work to recreate. I am a DIY technical guy and have recovered a few HDD previously with help from this forum. Thanks.
I would like to try to recover the data frlym this drive. I suspect it is panic/busy mode. It is not detected by BIOS in any computer. It died very suddenly. I did not realize that WD had released urgent firmware update that may have prevented this issue.
I read there are at least 2 different hardware versions of this drive. I suspect I have the newer (problematic) version, but am not 100% certain. Is there a way I can determine it?
I believe the newer version has the following controller? A101-000125-B0 (SANDISK) S220-TGYT77.0001 Am I correct?
If so, is there a way to user terminal software to recover the contents of the drive? I don't have PC 3000 but I can use terminal program and solder wires to the PCB if needed, etc.
I appreciate any guidance or help that can be provided. Thanks.
