 Post subject: SSD Not Working Properly. Showing Only 1 MB
PostPosted: September 8th, 2024, 3:50
Hello There,
I ahve one ssd Model Number ZEB-SD26 Sata 2.5". It comes with no power. When I check than i found that 2 capesitor and 6 pin voltage regulator damage which i mark in the image. I have same donor ssd and change the faulty parts. when i plugged it to computer, in device manager ssd showing "REALTEK_RL6643 an in disc management it show only 1 MB. Data is important. seeking help from your side. I haven't any MRT, PC3000 like tools.
SSD Image
https://img.eselt.de/img/16106603_bsGsW3YHkZOzT6nA/ad.jpg
 Post subject: Re: SSD Not Working Properly. Showing Only 1 MB
PostPosted: September 10th, 2024, 17:37
ROM mode (because that's the mode the disk is currently booting in) means no communication with the memory.
This is most often caused by damaged firmware.
If everything is working electronically, all that remains is to wait until support appears among the available tools.
Users browsing this forum: No registered users and 17 guests
