 Post subject: Sandisk BGA315
PostPosted: October 19th, 2024, 5:17
Hello guys,,
Anyone have an idea if there is a way to read this nand?
Full dump i mean..
BGA315
Thnx
 Post subject: Re: Sandisk BGA315
PostPosted: October 19th, 2024, 6:06
I've no idea how to read it, but I heard also this SanDisk uses LDPC ECC and adaptive XOR... So data recovery may be a really pain in *ss.
PostPosted: October 19th, 2024, 6:37
BGA315 to BGA100 adapter ?
PostPosted: October 20th, 2024, 2:02
Totally Diff.
PostPosted: October 20th, 2024, 13:28
Is there a controller on the other side of PCB or is it a FLASH with integrated USB controller?
PostPosted: October 20th, 2024, 19:40
I did some research on it, but currently I can only read 1CE/1LUN. This type of flash memory typically contains multiple LUNs. However, I cannot find the second physical CE. Changing the address range doesn't help either. So I can only read 1/2 or 1/4 of the chip's capacity.
http://flash-matrix.com/
PostPosted: October 21st, 2024, 1:38
@csava Thnx for the info.
PM sent :idea:
