June 8th, 2024, 10:05
Another extremely weird behavior I noticed, after deleting the partition, it now goes back and fourth from no partition to having an partition, but not formatted. Its definitely beyond repair.
June 9th, 2024, 14:17
Heres something interesting I found after using validrive. It looks like it only validated 16kb of storage space. Maybe the controller died?
- Attachments
Report.docx
- (18.28 KiB) Downloaded 449 times
June 9th, 2024, 16:35
ValiDrive is extremely clumsy as is demonstrated by its report. Just another of SG's f*ckups
The graph does not at all support the conclusion.
August 3rd, 2024, 6:30
Arch Stanton wrote:ValiDrive is extremely clumsy as is demonstrated by its report. Just another of SG's f*ckups
But that tool would work on confirming chinesium drive sizes?
And forgot to mention the drive went corrupt after being dropped from my desk (it was from around 80 centimeters). I guess the problem will be the controller or the flash itself (its unbranded with "HVNE4F4 1025" written on it).
August 7th, 2024, 9:07
Try cloning the drive with DMDE, then run R-Studio or Rundelete on the clone. If you're still getting corruption, cooling the NAND chip with freeze spray or measuring its voltage might help.
August 8th, 2024, 9:13
jackson77 wrote:Try cloning the drive with DMDE, then run R-Studio or Rundelete on the clone. If you're still getting corruption, cooling the NAND chip with freeze spray or measuring its voltage might help.
But whats the point of running R-studio on the cloned image? I couldn't find any options to repair corrupted files under rstudio and rundelete. Already measured the voltages for controller and NAND and tried freezing, cooling with compressor and putting a gpu heatsink with a fan on the NAND with less corrupted files, but still corrupted nonetheless.
December 9th, 2024, 9:01
What I found weird is that the drive gets unplugged on sector 713,600 when using LLF tool from here. And it always reverts the partition to RAW.
December 9th, 2024, 12:00
Still beating this dead horse?
December 10th, 2024, 14:57
I tired it just for fun but I still don't know whenever its the controller or nand. Probably I will find out someday, someday...
December 10th, 2024, 16:26
kotel wrote:I tired it just for fun but I still don't know whenever its the controller or nand. Probably I will find out someday, someday...
If it drops while scanning, it's the NAND.
