 Post subject: Help recovering data nvme m2
PostPosted: March 28th, 2025, 5:23
Hello everyone,
Apparently I did something stupid, not even sure how it happened.
I was using this 1tb kingston nvme as main drive w windows 11 and all my files on my previous laptop. no protection/encryption/bitlocker. I just removed the drive to sell the laptop and didnt backup because I knew my data wold be safe there until I installed on the new laptop. Had done it before multiple times without issues.
Here is the fun part... The new laptop is a asus f15 w 2 nvme slots, came w 1x 500gb drive and a empty slot.
Before booting the laptop, I open it to check ram model (upgrade later) and took the oportunity to also install my kinston 1tb drive. Ok all good intil here.
Thing is, this came w linux debian (keep-OS) pre installed, and during first boot, it must have either formatted or messed w my 1tb efi boot partition/files.
I proceed and isntalled windows on the oem 500g drive and can see my 1tb in disk manager/diskpart etc but it shows only as one "unknow" health partition, and all options on disk manager are greyed out meaning I cant assign a letter to it... Tried a bunch of recover programs (inside windows) and nothing seems to list any files there...
Any ideas what I can try at this point? Thank you!
 Post subject: Re: Help recovering data nvme m2
PostPosted: March 28th, 2025, 22:27
Probably partition was formatted in Linux file system (ext4 and so on), that's why it cannot be mounted in Windows.
It looks like no chances. I would bet all your data has been eaten by TRIM command after device was formatted in Linux.
PostPosted: March 29th, 2025, 4:24
Ouch .. thanks for explaining, that is probably what happened...
I was trying to recover the files (still in windows using different softwares) and found 19 superblocks, I read somewere its possible to recover them with a good success rate.
What would be the best approach to perform this? In windows? Maybe try booting from linix and do there? I have no idea never messed w it and those files are important, I appreciate any help!
