hi every one. can you guide me how to solve following issue:
sg_format --format --size=512 /dev/sg1 -v NETAPP X365_TPM3V1T6AMD NA04 peripheral_type: disk [0x0] PROTECT=1 << supports protection information>> Unit serial number: 9670A06MTWSC LU name: 500003974c88ba58 mode sense(10) cdb: [5a 00 01 00 00 00 00 00 fc 00] Mode Sense (block descriptor) data, prior to changes: Number of blocks=3125627568 [0xba4d4ab0] Block size=520 [0x208] mode select(10) cdb: [55 11 00 00 00 00 00 00 1c 00] mode select(10): Fixed format, current; Sense key: Data Protect Additional sense: Access denied - no access rights Sense_key: 0x7 unexpected MODE SELECT command: Data protect, type: sense key; write protected media?
sg_readcap -l /dev/sg1 Read Capacity results: Protection: prot_en=0, p_type=0, p_i_exponent=0 Logical block provisioning: lbpme=1, lbprz=1 Last LBA=3125627567 (0xba4d4aaf), Number of logical blocks=3125627568 Logical block length=520 bytes Logical blocks per physical block exponent=3 [so physical block length=4160 bytes] Lowest aligned LBA=0 Hence: Device size: 1625326335360 bytes, 1550032.0 MiB, 1625.33 GB
