Hello
I have this Kingston Data traveller that I want to try and recover.
Its not detected but voltages are present and they seem fine.
I tried finding an identical donor flash drive, to try for chip transplant - but no luck. I get sent either different models or fake flash drives.
From what I understand so far I need:
1. NAND Flash Reader with TSOP-48 adapter: - For example standard TL866II Plus with TSOP-48 adapter is fine? - where to buy? Of course I can google it, but I would like to be able to trust the tool at least a little when I'm just starting 2. Software: - Flash Extractor seems to be best choice, but its not available anymore. - I don't know what other software is recommended, I'm willing to spend money, but not PC-3000 money. 3. Resources: - I found some information on flash extractor website and on the PC-3000 solutions forum - I learn as I go, will do research to at least some idea about what I'm doing 4. After I get adapter and read the chip: - First make RAW dump, then experiment on making the data readable. Is that correct?
Any advice will be appreciated, thank you
