Need a GURU to attempt to repair my 4Tb HHD
June 3rd, 2025, 19:04
Hello. I have a fanxiang 4Tb HHD that I broke the connector for the data port while installing it in my son's new PC. I am pretty OK with soldering so I thought I will just replace the pcb connector and it will be fine.... sadly I feel my soldering skills and failing eyesight might have let me down. I somehow damaged a trace on the power port side (for Ground) and completely tore a pad off on one of the data lines. I repaired both of those, the internal LED's on the drive light up, The data pad was jumpered with wire to the side of a cap, and Ohm out, BUT the PC will not detect the drive. I am throwing in the towel before I make things worse....... A simple repair that was going great... till it was not has left me with a dead 200.00 drive. Anyone out there in the USA with a microscope and better skills than me willing to give it a shot?
I have already made an offer on another drive so my son can at least get his PC finally. But if I can get this repaired he can have another 4Tb Drive in his system.
Re: Need a GURU to attempt to repair my 4Tb HHD
June 4th, 2025, 0:22
Those fanxiang ssd drives are cheap and nasty, better to replace it. Post a picture of it
June 4th, 2025, 9:00
Here you go. You can see the 2 repairs I made in both the photos.
June 9th, 2025, 18:28
Anyone willing? I hate to just toss a Literal 200.00 Drive in the trash.
June 10th, 2025, 0:52
https://www.clubedohardware.com.br/uploads/attachments/monthly_2023_04/6.jpg.844b55bf621fbbfea0517b73a7c53231.jpg
See the "ROM" shorting pads above the two LEDs. Short them with tweezers before and after power-on, and then release the short after a few seconds. Is the SSD now detected, albeit it with a factory alias and reduced capacity?
June 10th, 2025, 12:29
That link you posted shows as invalid / does not allow external linking.
June 10th, 2025, 15:07
https://i.postimg.cc/FzgHv3f8/Fanxiang-SSD-PCB.jpg
June 10th, 2025, 15:13
DarrenA wrote:That link you posted shows as invalid / does not allow external linking.
I think the trick is to go to the web site ...
... and then enter the JPEG URL. At least that worked for me, after the initial rejection.
June 11th, 2025, 21:59
So IF I do this will it adversely effect the Drive?? I don't want to mess it up and end up with a 4Tb Drive that sees only 20 meg or something
June 12th, 2025, 4:05
It puts the controller into safe mode - it wont do anything permanent to the drive but forces it into as simple an operating state as possible - ie to check for ripped traces and the state of your soldering. If you get nothing from it like that then there are problems, if you do then there a problems with the firmware / nand. If you remove the short and then repower the drive it will return to it's normal state.
Either way - as ZeroAlpha has already mentioned, these are budget drives and unless there's data on them the juice is rarely worth the squeeze.
