 Post subject: ECC ERROR SM2258XT
PostPosted: July 28th, 2025, 22:56
Hi all, i am trying to understand why can't i recover this drive. Is it because of the Loader, ỏ the NAND or the controller of the SSD
So i got thí Eckoo chinese branded SSD. with a SM2258XT controller
1 NAND chip
Upon loading the Loader i got this error
Model : SM2258AB-80-10000000
Serial : (03)5526888-20080228
Firmware : 20141211
Capacity : 1 GB (2 096 640)
Selected family......................... : Crucial BX500
Controller.............................. : SM2258XT
SSD status:
SSD is in ready state................... : Yes
Firmware mode........................... : ROM
SSD error code.......................... : 0x00 (No errors)
SSD is locked........................... : No
SSD is in Safe Mode..................... : Yes
Logical access is possible.............. : No
Physical access is possible............. : No
Chips id................................ : EC1ED93F88CB
Vendor.................................. : Samsung
Type.................................... : 3dv4-64L TLC 16k
Loader uploading
MPISP code name......................... : S0212B0 SSV3_00; R1211A(N)
S0212B0 SSV3_00; R1211A(N).............. : Ok
Calling executable code................. : Ok
Invalid sectors per regions value (0xFFFF0000)
Seed table reading
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0004); ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0004); ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0004); ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0004); ECC error
Table not found
channel: 0; chip: 0; block: 0x0000; page: 0x0001............ : Invalid page type (Srv/ISP)
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0003)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0005)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0007)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0009)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x000B)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x000D)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x000F)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0011)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0013)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0015)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0017)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0019............ : Invalid page type (Srv/ISP)
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x001B)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x001D)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x001F)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0021)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0023)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0025)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0027)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0029)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x002B)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x002D)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x002F)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0031)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0033)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0035)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0037)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0039)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x003B)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x003D)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x003F)................. : ECC error
channel: 0; chip: 0; block: 0x0000; page: 0x0041............ : Invalid page type (Wear Tbl/ISP)
channel: 0; chip: 0; block: 0x0000; page: 0x0043............ : Invalid page type (Wear Tbl/ISP)
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0045)................. : ECC error
Page reading (channel: 0; chip: 0; block: 0x0000; page: 0x0047)................. : ECC error
channel: 0; chip: 1; block: 0x0000; page: 0x0001............ : Invalid page type (Srv/ISP)
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0003)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0005)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0007)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0009)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x000B)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x000D)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x000F)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0011)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0013)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0015)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0017)................. : ECC error
channel: 0; chip: 1; block: 0x0000; page: 0x0019............ : Invalid page type (Srv/ISP)
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x001B)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x001D)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x001F)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0021)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0023)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0025)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0027)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0029)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x002B)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x002D)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x002F)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0031)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0033)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0035)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0037)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0039)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x003B)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x003D)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x003F)................. : ECC error
channel: 0; chip: 1; block: 0x0000; page: 0x0041............ : Invalid page type (Wear Tbl/ISP)
channel: 0; chip: 1; block: 0x0000; page: 0x0043............ : Invalid page type (Wear Tbl/ISP)
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0045)................. : ECC error
Page reading (channel: 0; chip: 1; block: 0x0000; page: 0x0047)................. : ECC error
channel: 0; chip: 2; block: 0x0000; page: 0x0001............ : Invalid page type (Srv/ISP)
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0003)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0005)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0007)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0009)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x000B)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x000D)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x000F)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0011)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0013)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0015)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0017)................. : ECC error
channel: 0; chip: 2; block: 0x0000; page: 0x0019............ : Invalid page type (Srv/ISP)
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x001B)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x001D)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x001F)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0021)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0023)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0025)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0027)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0029)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x002B)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x002D)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x002F)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0031)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0033)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0035)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0037)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0039)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x003B)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x003D)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x003F)................. : ECC error
channel: 0; chip: 2; block: 0x0000; page: 0x0041............ : Invalid page type (Wear Tbl/ISP)
channel: 0; chip: 2; block: 0x0000; page: 0x0043............ : Invalid page type (Wear Tbl/ISP)
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0045)................. : ECC error
Page reading (channel: 0; chip: 2; block: 0x0000; page: 0x0047)................. : ECC error
channel: 0; chip: 3; block: 0x0000; page: 0x0001............ : Invalid page type (Srv/ISP)
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0003)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0005)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0007)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0009)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x000B)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x000D)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x000F)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0011)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0013)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0015)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0017)................. : ECC error
channel: 0; chip: 3; block: 0x0000; page: 0x0019............ : Invalid page type (Srv/ISP)
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x001B)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x001D)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x001F)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0021)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0023)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0025)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0027)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0029)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x002B)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x002D)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x002F)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0031)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0033)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0035)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0037)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0039)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x003B)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x003D)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x003F)................. : ECC error
channel: 0; chip: 3; block: 0x0000; page: 0x0041............ : Invalid page type (Wear Tbl/ISP)
channel: 0; chip: 3; block: 0x0000; page: 0x0043............ : Invalid page type (Wear Tbl/ISP)
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0045)................. : ECC error
Page reading (channel: 0; chip: 3; block: 0x0000; page: 0x0047)................. : ECC error
Firmware not loaded
SSD status:
Firmware mode........................... : LDR
SSD is in Safe Mode..................... : No
Physical access is possible............. : Possibly
Operation aborted
Loader is not uploaded! Some of the functions are not available!
So what can the error be? How can i recover this SSD?
Many Thanks!
Here is the Chip ID
 Post subject: Re: ECC ERROR SM2258XT
PostPosted: July 29th, 2025, 4:13
ECC errors are most likely due to the incorrect configuration of the memory modules used.
PostPosted: July 29th, 2025, 5:32
There are problems with those AB versions. Try different loader. Every one for SM2258XT.
PostPosted: July 29th, 2025, 23:14
Ok, i will give this a try
PostPosted: July 30th, 2025, 16:59
That loader (and other loaders) may not be compatible with the one from the SSD itself, hence trouble.
Users browsing this forum: No registered users and 127 guests
