 Post subject: Question flash memory retain data
PostPosted: November 17th, 2025, 18:03
NAND flash memory chips have a limited time to retain data, for example, 10 years at a certain temperature and write cycles.
If I only power this chip once a year, is that enough to retain data permanently? With only 2 or 3 write cycles performed.
Example chip: Hynix HY27US08281A
 Post subject: Re: Question flash memory retain data
PostPosted: November 17th, 2025, 19:30
It depends on what type of memory you are thinking about. SLC, MLC, TLC, QLC etc.
I meet SLC cases after 20-25 year, which generally no need ECC correction.
TLC,QLC need it immadietly after leaving the factory.
PostPosted: November 17th, 2025, 20:45
Chips de memory flash used in memory card de ps2
PostPosted: November 18th, 2025, 23:47
PS2 = NOR; but you knew that already.
PostPosted: November 19th, 2025, 3:56
IS Nand flash similar model mentioned, i have Bitfunx memory card ps2
Users browsing this forum: No registered users and 122 guests
