 Post subject: TeamGroup SSD Power Failure – No Visible Damage
PostPosted: December 11th, 2025, 5:51
I'm receiving a growing number of TeamGroup SSD drives that fail to power on completely:
    - No power-on response with or without PCB shorting
    - No behavior change when applying controlled heating
    - No visible signs of burning or physical damage on the board
    - The drives remain entirely unresponsive under all standard diagnostic procedures
Could you please advise on known causes for this issue or recommended next steps for diagnosis and recovery?
Thank you in advance.
Lamine
 Post subject: Re: TeamGroup SSD Power Failure – No Visible Damage
PostPosted: December 11th, 2025, 6:43
check the 0 ohm resistor (fuse)
PostPosted: December 11th, 2025, 10:01
Dear @pepe
Thank you for your reply.
Are you talking about this one?
Kind regards
Lamine
PostPosted: December 11th, 2025, 10:08
Measure the voltages at the 3 inductors.
PostPosted: December 11th, 2025, 11:04
Dear @fzabkar
Could you please help repair them on the card?
Thank you for your support.
PostPosted: December 11th, 2025, 11:06
https://www.google.com/search?imgtype=photo&q=inductor%20smd&tbs=isz%3Am&udm=2
yes, that one.
Check if it is open, if so, check if the 'bottom' end is shorted to gnd.
PostPosted: December 21st, 2025, 11:19
pepe wrote:
yes, that one.
This resistor shows 0.5 Ohm
The 3 inductors also show about 0.4 Ohm - 0.5 Ohm
Where could the problem be?
Thank you for your help
Lamine
PostPosted: December 21st, 2025, 14:40
Sorry, I can't help you.
PostPosted: December 21st, 2025, 17:31
Does this mean that the problem is elsewhere?
PostPosted: December 21st, 2025, 22:19
The problem is that you don't understand what is required.
Users browsing this forum: No registered users and 118 guests
