 Post subject: Problem with USB NVMe activity...
PostPosted: April 22nd, 2026, 8:40
I have a Transcend 2TB SSD based on the SM2320G controller (with built-in USB).
It's completely dead—no response, no LED activity.
I checked the pins of USB - are OK. And some voltages on the PCB—the drive is receiving power....
I don't know what kind of circuit this is - in the picture it's a 10-pin one - JSEMAM...
Has anyone encountered this?
Best regards
 Post subject: Re: Problem with USB NVMe activity...
PostPosted: April 22nd, 2026, 11:12
Did you try with safe mode? Those drives usualy give no response when FW is damaged and the only way is to recover with techno mode.
odzyskiwanie danych
PostPosted: April 22nd, 2026, 12:10
I've already noticed that.
I was confused by the LED's inactivity and the lack of ID.
Thanks, Krzysztof.
PostPosted: April 22nd, 2026, 12:29
JSExyz appears to be a Silergy 5V e-fuse or current-limited load switch. Check whether there is 5V at both input (C5?) and output (C6?).
PostPosted: April 22nd, 2026, 12:50
Thank you fzabkar for your reply.
But the drive is galvanically (electronically) fine.
It's just as melvin wrote – those NVMe drives with an integrated controller in the MCU (like the SM2320G) exhibit these symptoms.
Now just the PC3K, ROM mode, loader, translator recalculation, and... voilà.
Thanks again.
PostPosted: April 22nd, 2026, 13:15
I have seen several USB SSD products croak. It seems that components used are very low end parts that are not the most reliable.
Orico DS500C3-US-BK 5-disk 3.5" SATA, iTGZ 4x M.2 2280 Thunderbolt enclosure NVMe/SATA, etc. etc.
Users browsing this forum: No registered users and 17 guests
