 Post subject: 1TB 2230 NVME only recognized as 1MB - Need MPTool
PostPosted: June 4th, 2026, 17:46
Looking for PS5019-E19 (E19T) MPTool / factory package for SSSTC XA1-311024
I have a SSSTC XA1-311024 1TB M.2 2230 SSD that is not working. No data recovery needed, just want to use it again.
* Model: SSSTC XA1-311024
* PN: M1106370-007
* PCB: XA1-311024 REV 21
* Controller: Phison PS5019-E19-35
* NAND: SK hynix H25BFT8G5M3R-BDJ
Current symptoms:
* Enumerates as NVMe normally
* PCI Vendor 1987 (Phison)
* Firmware reported as EJRM01.2
* Windows detects disk as "PCIe SSD"
* Serial number present
* Capacity reported as exactly 1,048,576 bytes (1 MB)
* Disk appears Online/Healthy but RAW
* Flash ID utility shows 0 MB and cannot obtain NAND information
* SMART/reliability counters mostly blank
PowerShell reports:
FirmwareVersion : EJRM01.2
BusType : NVMe
I already found an E19 firmware BIN named EJF10002_05082021.BIN, but it appears to be from a different firmware family than EJRM01.2, so I am not willing to flash it blindly.
I am specifically looking for:
* PS5019-E19 / E19T MPTool
* EJRM01.2 factory package
* SSSTC XA1-311024 manufacturing package
* Matching config / parameter files for H25BFT8G5M3R NAND
Has anyone recovered a 1 MB-capacity PS5019 drive in this state, or does anyone know which MPTool branch supports EJRM firmware?
 Post subject: Re: 1TB 2230 NVME only recognized as 1MB - Need MPTool
PostPosted: June 8th, 2026, 5:27
EJRM01.2 is a masked ROM version. This state usually indicates a physical malfunction, such as a malfunctioning memory chip controller, etc. Such a drive is likely unrepairable without additional physical intervention.
Use the phison nvme flash id utility from VLO to obtain more detailed information about the chips map and its manufacturer.
PostPosted: June 8th, 2026, 10:47
Thank you for the info. This is what the utility showed when connected to nvme slot on the mobo:
v0.386a
OS: 10.0 build 26200
Drive : 0(NVME)
Driver : W10(0:3)
Model :
Fw :
Size : 0 MB [0.0 GB]
LBA Size: 1
CEL not supported
PostPosted: June 9th, 2026, 5:48
At least the controller type should be detected. There seems to be a driver issue here. Try connecting the drive via an NVMe-to-USB adapter.
PostPosted: June 9th, 2026, 9:48
This is what is shown in an enclosure:
v0.386a
Drive : 1(USB)
Bridge : JMS
Model : PCIe SSD
Fw : EJRM01.2
Size : 1 MB [0.0 GB]
LBA Size: 512
CEL not supported
PostPosted: June 10th, 2026, 6:05
You should use Phison nvme flash id, not Phison nvme flash id 2.
http://vlo.name:3000/ssdtool/
PostPosted: June 10th, 2026, 10:23
Enclosure:
v0.3a
Drive : 1(USB)
Bridge : JMS
Model : PCIe SSD
Fw : EJRM01.2
LBA Size : 512
Controller: PS5019-E19 in Rom Mode
FlashID : 0xad,0x5e,0x2a,0x33,0x0,0xa0,0xad,0x5e [0x0f 0x00 0x02 0x02] - Hynix 3dv5-96L TLC 16k 2048Gb/CE 512Gb/die
Bank00: 0x5e,0x2a,0x33,0x0,0xa0,0xad,0x5e -
Bank01: 0x5e,0x2a,0x33,0x0,0xa0,0xad,0x5e -
Bank02: 0x5e,0x2a,0x33,0x0,0xa0,0xad,0x5e -
Bank03: 0x5e,0x2a,0x33,0x0,0xa0,0xad,0x5e -
List of banks possible incorrect
PostPosted: June 12th, 2026, 14:16
I am reading from online help that Flash ID v1 reports PS5019-E19 in ROM Mode and successfully reads Hynix 3dv5-96L TLC NAND IDs on all banks. Does this indicate a missing/corrupted firmware configuration and would a PS5019 MPTool rebuild be the appropriate next step? If so, how to obtain it?
PostPosted: June 12th, 2026, 16:19
I suggest getting a new SSD instead of fighting this corpse of a SSD
Orico DS500C3-US-BK 5-disk 3.5" SATA, iTGZ 4x M.2 2280 Thunderbolt enclosure NVMe/SATA, etc. etc.
PostPosted: June 12th, 2026, 16:22
I have other ssds and data recovery isn't a problem. Trying to bring this back to life
Users browsing this forum: No registered users and 17 guests
