Post new topic Reply to topic  [ 30 posts ]  Go to page 1, 2  Next
 Post subject: How to fix the SSD of the body of this thread using RAID?
PostPosted: August 10th, 2026, 18:10
Can I fix the SSD drive if it was damaged while using RAID mode with a MAXIMUS XI Gene 2400 version UEFI BIOS, a Seagate ST1000DM003-1SB102 1,000.2 GB SATA III 6 Gb/s internal HDD, and a KingSpec P3-256 256.0 GB SATA III 6 Gb/s internal SSD( this is the drive is need to fix), configured with the SATA Port set to Super Speed and the Storage Configuration set to RAID 0? If the answer is yes, how can I fix it?
 Post subject: Re: How to fix the SSD of the body of this thread using RAID
PostPosted: August 11th, 2026, 4:19
If you're asking about a repair, it means you know what's broken. The cause of the damage, not that "the SSD isn't working."
We don't know what components the drive is made of.
We don't know if it's communicating properly.
The answer to this question is yes/no/unknown.
A very strange configuration for one SSD and one HDD...
Manual:
1.1.1 RAID definitions
RAID 0 (Data striping) optimizes two identical hard disk drives to read and write data in
parallel, interleaved stacks. Two hard disks perform the same work as a single drive but at a
sustained data transfer rate, double that of a single disk alone, thus improving data access
and storage. Use of two new identical hard disk drives is required for this setup.
I would rather expect a configuration with Intel Optane, but the drives used do not indicate this.
If you want to do anything through the forum, you need to provide key information.
Besides the information mentioned above, did you connect this HDD as a secondary drive? What does the partition screen look like in DMDE?
PostPosted: August 11th, 2026, 18:17
The raid mode was created using a ASUS ROG Maximus Xi Gene motherboard and the 2 previously mentioned internal storage devices, the components the drive is made of is on the first 2 attached images],the SSD is properly communicating to the pc, i didn´t installed and configured Optane Memory and partition screen looks like the last attached image in DMDE.
PostPosted: August 11th, 2026, 18:18
What else do you consdier key afirmation?.
PostPosted: August 11th, 2026, 18:20
I submitted a reply that is currently awaiting approval. I didn't realize you wouldn't be notified, which is why I didn't wait for the reply to appear before posting my previous comment.
PostPosted: August 11th, 2026, 18:23
i will edit it.
PostPosted: August 11th, 2026, 19:03
When I wrote 'I will edit it,' I meant that I was going to edit the exact same reply. However, since I didn't do it early enough before the editing window was disabled, I will write what I intended to say there: 'I will provide the S.M.A.R.T. data of the HDD that is currently configured in RAID mode with the previously mentioned SSD (I won't repeat that these are not the storage drives I used to enable RAID mode with another one). This is because the previously mentioned SSD is the one that was configured with another HDD in RAID mode, and that is the SSD I want to fix.
PostPosted: August 11th, 2026, 19:07
I edited previous reply.
PostPosted: August 11th, 2026, 19:18
Please forgive me. From now on, I will not write any messages that are not absolutely vital for people to help me. Please help me, and if I break this rule, do not do it anymore. I didn't know that replies to the forum thread that weren't absolutely necessary would prevent people from helping me.
PostPosted: August 11th, 2026, 20:15
Please mention if it is absolutely necessary to give the S.M.A.R.T. of the HDD I used to install and configure the RAID mode to fix the SSD I used with it to install and configure the RAID mode.
PostPosted: August 11th, 2026, 22:22
Your DMDE screenshot does not show a RAID. It is showing a 256GB drive with several partitions that span a single 256GB drive, not a 2 x 256GB RAID 0.
D-click the $Noname partitions and expand the $Root. You should see a file/folder tree under each.
PostPosted: August 12th, 2026, 4:21
As fzabkar writes, the DMDE configuration doesn't contain information about any RAID array, the NTFS partition itself is damaged.
But before you begin data recovery, make a binary copy of this drive in case it suffers more serious damage.
PostPosted: August 12th, 2026, 18:05
I will attach what is shown after double-clicking the $Noname partitions and expanding $Root, showing the folders\files under each one in chronological order, from the screenshot that appears higher up to the one that appears lower down, across this and the following comment, in chronological order from the first to the last of those two comments.
PostPosted: August 12th, 2026, 18:25
This is the second part of what is shown after double-clicking the $Noname partitions and expanding $Root, showing the folders/files under each one. After configuring the RAID mode, I removed the HDD I had installed and configured the RAID mode alongside the SSD I mentioned there (the one I want to repair and am asking you how to repair). I then connected another HDD, installed Windows on it, and afterward connected the previously mentioned SSD. In the BIOS/UEFI, under Advanced → PCH Storage Configuration → SATA Mode Selection, it was set to AHCI, after previously having been configured as Intel RST Premium With Intel Optane System Acceleration (RAID). I had only installed and configured RAID mode with the penultimate-mentioned HDD and the previously mentioned SSD.
PostPosted: August 12th, 2026, 19:06
There is the S.M.A.R.T. result for the previously mentioned SSD attached in chronological order, from the screenshot that appears higher up to the one that appears lower down.
PostPosted: August 12th, 2026, 19:20
The current temperature in my last two attached pictures was taken at the last available time.
PostPosted: August 12th, 2026, 20:12
The partition screen looks like the one shown in the attached English image in DMDE.
(Así luce la pantalla de partición en DMDE inglés).png [ 78.98 KiB | Viewed 895 times ]
PostPosted: August 12th, 2026, 21:42
I don't have any experience with Optane configurations, and I can't see how your SSD fits into such a setup. Normally the SSD provides a high speed cache while the slower storage device provides the bulk storage. You can't separate the two because their file systems are intertwined. It's not really a RAID. You need to wait for one of the pros to advise you.
PostPosted: August 12th, 2026, 21:51
The attached images were taken after I did what I mentioned in my fourth-to-last reply, counting this one, on an OS installed on the SSD mentioned there.
PostPosted: August 13th, 2026, 2:45
If this were an Optane configuration, you wouldn't be able to see the data structure on a single drive. Is your profile and data in the User directory?
