 Post subject: NFTracer Recent Update Log
PostPosted: August 26th, 2026, 4:36
Ver3.26.8.26
1、Added dynamic XOR algorithm for SM3265 series
2、Added layout and sector sorting algorithm for one Samsung TF card; LDPC check algorithm is undertesting
3、Added ADDE14A7reread command for hynix_v7
4、Added models:
SM3281_89C40832A600_2x4_by Beast
IS918_2CA4E554A900_1x2_by Csava join pagebefore operation
IS918_983E980376E4_1x1_by fxc
unknow‑TF_453E98B3766B_1x1_by mfz
5、Added layouts:
Innostor(IS) IS918v2 1126x16
Monolith unknow‑TF 1146x16
SamSung MicroSDv1 36+2272x8
JMicron(JM) JmSDv3 1142x16
Ver3.26.8.17
1、Fixed an issue whereswitching layout would cause shear‑byte step errors when shear‑byte steps werepresent
2、Added CBM sector sorting algorithm
3、Added automatic bad‑byte shearing
4、Added models:
PS2251‑19_AD89285300B0_2x1_by mfz
SM3281_AD7E285302B0_2x1_by Aday
SG7081_AD5C282A0190_1x1_by fxc
5、Added layouts:
IS918 1144+1136x15
SM3265v2 1138x16+32
SM3265v2 1140x16+32
SG1581/7081 1150x7+1158
CBM2399 1152x16
Ver3.26.8.10
1、Fixed the issue where data read errors occurred when ECC correction was disabled.
2、Optimized LDPC correction speed, achieving approximately 2‑fold performance improvement.
3、Added models:
PS2251‑09_453C98B376E3_1x4
SM3281_AD5E283300A0_1x2
CBM‑TF_ECDE88BF90C6_1x1
PS2251‑11_983C98B376E3_1x1_ldpc
SM‑TF_453E98B3766B_1x1
SM3265P_89D40C32AA00_1x1_by czj
SM3281_2CC40832A2002x1_by 900
4、Added layouts:
SM‑TFv3 1142x16+32+32
UP309v2 1138x16
FC3379 1162+1146x15
SM3271 1136x8+31
CBM2199v2 1115x8
CBM2199v2 1103x16
Ver3.26.7.23
1、Added function toset partition start offset after opening image
2、Added LDPC ECCsupport for PS2251-11 1144x16 and YS9082 (2304+2308)x4
3、Fixed issue whereediting and cutting bytes/bits failed to take effect with multiple dump
4、Added the following models:
SM3265_45489803766C_1x1_by900
FC3379_453E9803766C_1x2_byfxc RAW
IS918_EC5E981F84C2_2x1_byAday
AU89103_453E9803766C_1x4_byCsava BGA304
IS918_983C98B376E3_2x1_byfxc
SM2236_2C84643CA900_1x4_byCsava
SM3281_2C2CD31C32C600_1x4_byCsava
SM3281_2CA40832A100_1x1_byBeast
PS2251-19_983E98B376E3_2x1_byCsava 1FF0 L=0x0C
JmSD_AD7E285302B0_1x1_byfxc
IS918_2CD31C32C600_1x1_byCsava
HG2319v4_EC5E981F84C2_1x1_byCsava 0FF0 L=0x0C
IS918SN_983E9803766B_2x1_Sectornumber
IS918SN_983E9803766B_1x1_Sectornumber
SM3265_98489803766C_1x2_by900
SM3265_AD7E280B00C0_1x2
AS-TF_AD5E283300A0_1x2_byfxc
SM-SD_EC3A94C3A4CA_1x4_byfxc
AU89103_89C40832A600_1x4_2banksmodify SN_Slow
5、Added Layout:
SG1581/7081v21150x15+1158
SM3265v3 1158x16+32
SM-TFv2 1148x16+32x2
IS918v6 1152x16
CBM2199v3 1144x16
AU8910 1146x16
SM3271 638x26+32
CBM-TF 1152x16
PS2251-11 1144x16
website: https://www.flash-tracer.com/
