 Post subject: What is the internal "sector size" (page size?) of a SSD?
PostPosted: Yesterday, 5:05
is there something like a range or a common value describing how much data is written physically when I trigger a write operation on an SSD?
For example, I create a new file and write 1 byte at file position zero and close the file afterwards.
On my Windows NT filesystems which have a cluster size of 8 sectors, one free cluster of 4096 bytes will be used for the data.
How much space will the SSD use for that 1 byte of information internally when performing that incoming write command for the data?
Is that more or less space? Are there typical values?
 Post subject: Re: What is the internal "sector size" (page size?) of a SSD
PostPosted: Today, 0:06
It's more likely the SSD controller would buffer it and combine it with other writes, place it into part of a NAND page (~ 16K depending on the generation). It's a hard question to answer as your single write also creates filesystem metadata and such. And then there is garbage collection aspects to consider.
It's not a black and white answer...
Users browsing this forum: Bing [Bot] and 122 guests
