How to clone USB Drive
June 17th, 2007, 1:48
Dear : All
I use copyr or media tool prof to clone badsector HDD; but the software don`t support USB drive.
Is there software that support to clone badsector USB drive ?
thanks
June 17th, 2007, 3:01
Can You Share Your Problem You Have Now ,Software Will See Drive if Electronics Are Good
June 17th, 2007, 3:35
The USB drive detect in winxp but partition is RAW and I run getdataback for FAT32 and in LBA ...., appear message : read error; I skip this error; but next time appear message again and I skip; the process until finish need two hour.
I can recover 80% JPEG; but 10% is corrupt.
I check USB drive with HDDscan; and I see few badblock;
The USB drive tend to broken, so I will clone USB drive to another;
How to do this ? please
thanks for your reply
June 17th, 2007, 6:36
Tip of The Day,
Resolder everything ,Try Works Good ,Otherwise Keep Resoldering And Trying .Remeber To Clean And Dry the Flux Using FLux Cleaning Solution Like IPA Etc
June 17th, 2007, 13:19
Media tools could work with the usb if u install usb driver for DOS .
June 19th, 2007, 18:18
Rameez,
Is Media Tools Your Most Lovable Tool .How You Rates This To Other Solutions
June 20th, 2007, 14:00
i suggest everyone to use Media tools because it is real fast and can clone from bad sectors and also i have recovered many files from this tool which others where not able to find .
June 21st, 2007, 14:31
Winhex its very good too for clone
