 Post subject: SD Card on Serial Port
PostPosted: October 16th, 2007, 11:37
I thought I would add to this discussion. I have an SD card that will not recognize in Linux(then of course not windows). It shows up temporarily, then gives errors. I was thinking about using a serial connection(rs232) to send/receive commands and data. Does anyone have pinout information for SD cards? I'm just planning to use inport/outport C functions to get the info.
Thanks for any info.
A
 Post subject: Re: SD Card on Serial Port
PostPosted: October 16th, 2007, 15:55
Hi acforensics,
Here you can study the connections:
http://www.interfacebus.com/Secure_Digi ... inout.html
Bosse
http://www.rescue-it.se
PostPosted: October 16th, 2007, 17:27
I had a USB flash drive that did something similar, flashed up momentarily then disappeared.
I used DE in Windows 2000, to image it to a small HDD.
Then was able to extract data from the HDD.
Hope it helps
PostPosted: October 16th, 2007, 18:27
Hey Sean,
What does DE use? BIOS? Direct IDE commands? Did you connect the card via a USB card reader?
Thanks for your help.
Andy
PostPosted: October 17th, 2007, 3:07
Via USB, if it's a valid device DE will pick it up ;-)
Or failing that, use a SC>CF adaptor, and plug that into a CF>IDE adaptor.
PostPosted: October 17th, 2007, 11:58
Sorry. What is a SC>CF adapter? And CF>IDE adapter?
PostPosted: October 19th, 2007, 15:56
oops. sorry
SD > CF = SD to Compact Flash adaptor.
CF>IDE = Compact Flash to IDE Adaptor
CF>IDE easy to find and dirt cheap
SD>CF, not so easy and more expensive
ebay ;-)
Users browsing this forum: No registered users and 114 guests
