 Post subject: SD 4GB recognized only 2gb
PostPosted: July 2nd, 2009, 4:47
I have one SD 4Gb. When i try to read this in pc3 flash, it read only 2gb. The chip memory is MT29F16G08MAA, i don't know the controller because is covered. When i try to recover files, with Block Number Type1 i see the root, folders and files, but the files are corrupt.
I need help!!
Regards!
 Post subject: Re: SD 4GB recognized only 2gb
PostPosted: July 3rd, 2009, 9:46
There may be 2 banks. Check the datasheet.
https://www.mjm.co.uk/
PostPosted: August 1st, 2009, 23:41
I need help!!
Regards!
In PC3K ,do u select 2 chips? and compare the symbol on chip?
Most cases in wrong size, maybe caused in bad controller!
I am confused about you said it covered , and how do you use block number function?
PostPosted: August 3rd, 2009, 8:26
I need help!!
Regards!
I assume that there is only one memory chip in your card. I there is two, disregard from this post. You can't read more than 2GB because the chip size is only 2 GB. Is it a no-name SD? I think it is a fake card. Treat the chip as a 2 GB card as it is and try to recover it. When you do the high level recovery, be aware of the partition size which also most probably is wrong!
