Re: ADATA Premier Pro SP900 shorting everywhere
July 9th, 2026, 19:03
fzabkar wrote:A Vcore voltage of 1V is OK, as I understand it. The supply voltage seems unaffected by the low resistance. I just don't understand why your two Vcore resistance readings differ.
What can a half bad resistor do?? I mean something is definitelly affecting the Vcore resistance at the resistors
July 10th, 2026, 10:14
Measure the resistance between the L2 inductor and your "shorted" capacitors. Is it 0 ohms?
July 10th, 2026, 15:15
They have from 190 to 220 ohms
July 10th, 2026, 15:32
The attachment SHORTING POINTS 200.JPG is no longer available
I have this Strange resistor. It is not shorted to ground. However when measured between the inductor. It beeps and shows 1 ohm on 1 side and 200 on the other
July 10th, 2026, 15:40
Can you take a better picture so we can see what the component you mean and the circuit board / traces around it.
July 10th, 2026, 15:59
Lardman wrote:Can you take a better picture so we can see what the component you mean and the circuit board / traces around it.
Here you go
FRONT
BACK
July 10th, 2026, 17:43
I think that the anomaly can be explained by power sequencing.
I believe that U6 is a dual step-down converter, MP5506, by Monolithic Power. Unfortunately I can't find a datasheet.
Q1 and Q2 are N-channel MOSFETs (DMG6968U). They appear to be switching the two outputs of the buck converter (1.0V and 2.9V) on and off under the control of U6. The reason that you measure different resistances is that you are measuring different sides of the MOSFET switch when it is turned off. When then SSD is powered on, the switches are closed (MOSFETs turned on) and the voltages are the same on both sides (Drain and Source). In fact, please measure the voltage at the VCC_NAND-Switched test point.
It would appear that one of those capacitors is leaky, but not shorted. This does not prevent the Vcore supply from coming up.
In short, I believe the low resistance is a distraction and the actual problem is firmware related.
DMG6968U, Diodes Inc, N-ch MOSFET, marking 2N4, SOT23:
https://www.diodes.com/datasheet/download/DMG6968U.pdf
July 10th, 2026, 18:15
This is U5.
MP2136, Monolithic Power, stepdown converter, 2.5V - 6V Input, 2MHz, 1A, marking 6Q, QFN6:
https://www.farnell.com/datasheets/2914869.pdf
July 10th, 2026, 18:44
   .-----------. L3  ---    GND     ===      ---   GND
   |   on/off  | ___  |             |^| Q2    |
   |           |-UUU--+-------------+|+-------+-------o   VCC_NAND_switched
   |           |    VCC_NAND
   |  MP5506   |
   |           | ___ Vcore
   |           |-UUU--+-------------+|+-------+-------o   Vcore_switched
   |   on/off  | L2   |             |V|       |
   '-----------'     ---         Q1 ===      ---
         |           ---              |      --- 20 ohms
         |   210 ohms |               |       |
         |           GND              |      GND
July 11th, 2026, 9:18
because the light indicators on PC3000 Portable Pro only shows that way when there is a short on the board. If the board is not shorted the light should came in BSY if there is a problem with Firmware of the drive
this only means the sata interface is not configured, which happens when fw fails to load as well. Since in rom mode it works well, it points towards fw corruption. I aslo met this kind of thing in the past...
verifying supply rails is a good idea, but most likely the issue is fw related.
July 11th, 2026, 10:44
pepe wrote:verifying supply rails is a good idea, but most likely the issue is fw related.
Is 20 ohms a normal resistance for this core? My understanding is that Sandforce didn't use ARM cores, so a figure of ~100 ohms may not be a reasonable assumption.
July 11th, 2026, 16:44
This document has a block diagram which confirms the three supply voltages -- 1.8, 1.0 and 2.85V.
SandForce SF2000 Reference Design and Evaluation SSD:
https://www.seagate.com/files/www-content/product-content/lsi-fam/enterprise-flash-controller/en-us/docs/enterprise-sf-2000-refevalssd-ds1829-1-1409us.pdf
Interesting blog:
SandForce SF-1200 & SF-2200 SSD Controller Architecture:
https://rossmanngroup.com/services/ssd-data-recovery/sandforce-controllers
July 11th, 2026, 19:58
fzabkar wrote:I think that the anomaly can be explained by power sequencing.
Can you point out for me whera ar the VCC_NAND-Switched test points?
July 11th, 2026, 20:07
It's marked in the top right of my annotated photo clip.
July 12th, 2026, 7:48
VCC NAND TEST POINTS are 2.8V
July 12th, 2026, 7:59
That's OK.
July 13th, 2026, 15:53
fzabkar wrote:That's OK.
oh well
July 16th, 2026, 5:10
So i just found a board with the same Controller. However not the same layout. However i think the volt stages should be the same
I measured these caps that on the 1V rail. And they are not shorted. All of them shows 200 ohms-250 Ohms
So there is definetelly a short on my SSD. Where is the short i don't know yet
I measured these ones
July 16th, 2026, 5:37
The Vcore supply powers the controller. The controller is obviously working, so the low resistance can only be due to a leaky capacitor. A short would shut down the supply, which is clearly not the case here.
July 16th, 2026, 14:13
I went down a similar rabbit hole with a sandisk SSD I swore blind was a hardware problem. Im sure Franc remembers the case :lol: after 8 donors and a full nand and controller swap with an identical donor pcb I finally accepted it was firmware and nothing more could be done despite what it looked like to me. I was trying to fix the fault I wanted it to be rather than the fault it was - expensive lesson.
