October 1st, 2026, 5:52
gold6565 wrote:I found a firmware file I had—I was interested in it at one point, but after looking at the contents, I lost interest. I didn't even finish reading it through.
October 1st, 2026, 6:10
October 1st, 2026, 6:54
HannsGruber wrote:gold6565 wrote:I found a firmware file I had—I was interested in it at one point, but after looking at the contents, I lost interest. I didn't even finish reading it through.
Yep, I have that file. It falls out when you unpack the iso. It's still AES256 encrypted, it's sent over to the drive encrypted and decrypted on the device. It has some metadata you can look at, but the body is encrypted.
October 1st, 2026, 8:26
gold6565 wrote:HannsGruber wrote:gold6565 wrote:I found a firmware file I had—I was interested in it at one point, but after looking at the contents, I lost interest. I didn't even finish reading it through.
I haven't seen that in ISO images. That is the format in which the firmware is stored on the SSD.
October 1st, 2026, 19:37
michael chiklis wrote:The picture doesn't mean nothing, just pretending doing reverse engineering.
Neither AceLab has't found yet a solution to "hack" 860 evo fw
October 4th, 2026, 1:53
October 14th, 2026, 12:36
October 14th, 2026, 23:49
sourcerer wrote:The hardware side of the 860 EVO is likely similar to the EVO840 I analyzed a few years ago: https://futureware.at/~philipp/ssd/TheMissingManual.pdf
I saw the same repetitions of the memory blocks in the 840, and that's expected given how memory maps are being layed out in hardware. (It's cheaper that way)
