June 19th, 2025, 9:34
jga1982 wrote:Hi all!
I have ATA password problem with SSD Samsung PM851 MZ-7TE5120 MZ7TE512HMHP-00004.
It was be installed in to the laptop with touch ID scanner, and activated protection in BIOS. I think, BIOS set some ATA password in to the SSD. This laptop is no longer there, and I cant unlock my SSD.
This is OEM product, and Samsung didn't support it on website and in Magician application! Also i can't find firmware ext0300q.enc at the web for it.
I shorted 2 pins (red), and try run HDPARM , but this did not help solve the problem!
August 18th, 2025, 6:30
Shorting the EN pin #6 of the MP5505 chip should have worked. That's what both of us did.maki wrote:Hi![]()
I have a locked PM863a SAMSUNG MZ7LM3T8HMLP-00005 here.
I unsuccessfully tried shorting the EN pin #6 using tweezers, described here: https://forum.hddguru.com/viewtopic.php ... 99#p305499
The drive resets and then its still locked.
Shorting the pins like here dind't do anything: https://forum.hddguru.com/viewtopic.php ... 41#p308841
I have it attached via an Adaptec 82885T expander which in turns is attached to to a LSI 9305-i24, cold that be the reason?
Any suggestions?
August 27th, 2025, 7:55
