 Post subject: 16GB MicroSD Card Corrupted! Can't format! Help!
PostPosted: March 20th, 2009, 13:11
OK, so I got a G1 Android phone (it kicks iPhone arse) and I have a 16GB MicroSDHC memory card. I used Paragon Partition Manager to format the card with a 14GB FAT32 partition and 2 GB for Ext2 Linux (I found a hack where you can download, save, and run G1 apps from the memory card using ext2). No problems, it formatted the card and I verified the partitions were good. Started using it in my G1 and it worked like a "dream". Then about a week after I did it, my G1 bricked (it's rooted) and I finally realized it was the memory card. Took it out popped in a new one and the phone works again. It seems the ext2 partition is fine but the FAT32 is corrupted and unreadable. I tried elevated command prompts in Windows and the format function in Paragon in addition to ZAR and SDFormatter and none of them can read or format it.
I think it's stuck in read only mode somehow. When I run format e: in cmd.exe it tells me the data is RAW and cannot be formatted. I tried releasing all handles on drive but that didn't work either. But when I stick the card into my laptop, it reads all the FAT32 data and I can even open Explorer window and see all my files from the Fat32 partition. But I cannot copy, delete, or move them. And again, I cannot format it.
There are bad sectors but I think it's a software problem because my card looks undamaged and it's been in my phone the whole time. I just need to erase the frackin thing!
Is there any way to force format the whole 16GB, delete the partitions, and start over in MSDOS or Vista?
Users browsing this forum: Google [Bot] and 127 guests
