| USB Flash memory "corruped CHIP is possible" http://forum.hddguru.com/viewtopic.php?f=10&t=11775 |
Page 1 of 1 |
| Author: | zebong [ March 27th, 2009, 15:57 ] |
| Post subject: | USB Flash memory "corruped CHIP is possible" |
Hi to all, Have a USB 1Gb stick that came to me with the first sectors OK, But from the sector xx to the end, when i edit the sectors it have all like the picture. Can be corrupetd chip, is possible to get anything here Attachment: usb.jpg [ 103.39 KiB | Viewed 12920 times ] Thanks ZeBong |
| Author: | pcimage [ March 27th, 2009, 18:08 ] |
| Post subject: | Re: USB Flash memory "corruped CHIP is possible" |
Sector xx? How many? |
| Author: | zebong [ March 27th, 2009, 18:54 ] |
Sector 0 and 32 , 38 , 44 , 70 with data ( fat32) the rest is "00" with data from sector 4644 to 5080 from 5081 to 5098 with "00" from 5099 to 2 044 414 with "FF" Last sector 2 044 415 "00" Have this when editing the sectors. |
| Author: | pepe [ March 27th, 2009, 19:23 ] |
seems it is almost empty, probably hardly ever used. Doesn't seem like corrupted, u could not read from it in that case. |
| Author: | pcimage [ March 28th, 2009, 5:48 ] |
Either that or wiped. Have you actually tried a s/w recovery? |
| Author: | zebong [ March 28th, 2009, 8:17 ] |
Yes the first thing to do. Just appear one file but is not completed. something happen and all the rest it looks like wipe out. |
| Author: | HardDiskBug [ March 28th, 2009, 13:25 ] |
Someone may have tried poking in it with it's production tool, and have re-written the controller Info? It happens in that cases.. |
| Author: | dick [ March 28th, 2009, 15:22 ] |
How are you reading the data? Directly from the stick or with the chip removed in a programmer? Have you tried to rework the soldered connections to the memory chip/s? I would try that next. |
| Author: | zebong [ March 28th, 2009, 18:55 ] |
dick wrote: How are you reading the data? Directly from the stick or with the chip removed in a programmer? Have you tried to rework the soldered connections to the memory chip/s? I would try that next. I am reading directly from the stick. Will try that. Can be the algorithum / encryption , have some problem ? |
