 Post subject: SD 4GB recognized only 2gb
PostPosted: July 2nd, 2009, 4:47
I have one SD 4Gb. When i try to read this in pc3 flash, it read only 2gb. The chip memory is MT29F16G08MAA, i don't know the controller because is covered. When i try to recover files, with Block Number Type1 i see the root, folders and files, but the files are corrupt.
I need help!!
Regards!
 Post subject: Re: SD 4GB recognized only 2gb
PostPosted: July 3rd, 2009, 9:46
There may be 2 banks. Check the datasheet.
https://www.mjm.co.uk/
PostPosted: August 1st, 2009, 23:41
I need help!!
Regards!
In PC3K ,do u select 2 chips? and compare the symbol on chip?
Most cases in wrong size, maybe caused in bad controller!
I am confused about you said it covered , and how do you use block number function?
PostPosted: August 3rd, 2009, 8:26
I need help!!
Regards!
I assume that there is only one memory chip in your card. I there is two, disregard from this post. You can't read more than 2GB because the chip size is only 2 GB. Is it a no-name SD? I think it is a fake card. Treat the chip as a 2 GB card as it is and try to recover it. When you do the high level recovery, be aware of the partition size which also most probably is wrong!
Users browsing this forum: No registered users and 145 guests
