| difference between pc-3000flash and flash doctor? http://forum.hddguru.com/viewtopic.php?f=10&t=13636 |
Page 1 of 1 |
| Author: | cakedi [ October 12th, 2009, 22:28 ] |
| Post subject: | difference between pc-3000flash and flash doctor? |
difference between pc-3000flash and flash doctor? any solution? and give reason? |
| Author: | shahij [ October 13th, 2009, 13:11 ] |
| Post subject: | Re: difference between pc-3000flash and flash doctor? |
pc3k is developed by ace where flash doctor is developed by SD. similar by feature. |
| Author: | Money fan [ October 21st, 2009, 8:02 ] |
topic is not actual already, moreover if you say your opinion about some products, you are accused of protecting somebody's interests... |
| Author: | poehere [ October 21st, 2009, 12:21 ] |
Flash Doctor by SD has a limit to the size of the chips that it can read. It can not read large configureations and the two dump files are not interchangeable. The Flash from SD is nicely done becasue you can change out this piece if you have a problem. Some chips can be read by Flash and have a problem reading them by Flash 3000 but think this is all technique and need to play with both of them and they are both good devices and you can read up on both of them and choose which one you want. |
