Post new topic Reply to topic  [ 35 posts ]  Go to page 1, 2  Next
 Post subject: flash usb reocvery tools
PostPosted: January 17th, 2010, 14:21
Any one have good experience to give as advice witch is the best tool to recover usb flash between :
1-pc3000 flash
2-flash doctor from salvationdata
 Post subject: Re: flash usb reocvery tools
PostPosted: January 17th, 2010, 20:11
Flash Extractor from Soft Center :)
PostPosted: January 25th, 2010, 4:48
I also use flash extractor.
Call Center Outsource
PostPosted: January 25th, 2010, 15:47
Me too
PostPosted: January 26th, 2010, 5:05
Dont buy any if if data recovery volume for flash is low. ACE flash needs contants feeding with EUROs if the TS is ran out, and you dont get update. which i think is a daylight robbery.
PostPosted: January 31st, 2010, 6:01
SoftCenter here aswell :D
http://www.rescue-it.se
PostPosted: January 31st, 2010, 22:45
Does SoftCenter gives free updates and tech support?
PostPosted: February 1st, 2010, 11:49
yes
PostPosted: February 2nd, 2010, 3:52
I am switching to SoftCenter :) can't stand with ACE bullshi# TS TS TS EURO EURO EURO.....
PostPosted: February 3rd, 2010, 10:45
Another vote for Softcenter
PostPosted: February 8th, 2010, 4:33
Dear arvika
Could u pls send me the company URL i'll be appreciate.
Thank u a lot
Readsea
PostPosted: February 8th, 2010, 11:35
redseaksa wrote:
Dear arvika
Thank u a lot
Readsea
http://www.soft-center.ru/
PostPosted: February 27th, 2010, 1:53
Can someone explain to me the price structures, very very confusing to me.
The Flash reader Unit cost is $210
then what are those bits and pieces? Mix editor $87, Block_number $74, $31, etc???
If i want the complete unit just add $210 + $74 + $31 ?????
PostPosted: February 27th, 2010, 6:02
exactly
U can buy sw modules as u need them.
PostPosted: February 27th, 2010, 22:34
so what you just buy is the following flash reader unit which cost $210 usa
that covers all nand version
and when you need the other sw modules you buy them
how is the programming looking would anyone say its on the same line as ace flash recovery unit or salvation data.
i looked at salvation data but there no english studies on there unit :(
plus the russian one how good is the program to use
PostPosted: February 28th, 2010, 4:51
I might have the same problem, my usb-stick
- LED blinks normal when inserted
- gives a windows code 10 error (three ding-sounds)
- linux udevinfo, lsusb report flashDrive present, but no /dev/sdxx node is made
Flash-memory was corrupted?
Does the russian programme access the flash-memory-chip differently though USB?
Can the chip be talked-to in a low-level access via USBus?
PostPosted: March 11th, 2010, 5:31
Hi all guru ,soft center tool can recovery flash files succesfully 100%
I want ot get one !
Anyone Could give me some advices
PostPosted: March 12th, 2010, 10:42
Any tool is useless unless u have some basic, preferably deep knowledge in the field.
PostPosted: March 17th, 2010, 13:43
Well Pepe Sir ,
For Flash Its FAT32 File system Knowledge ,If Someone Has that Its Greatttttttttttttttttt
PostPosted: March 17th, 2010, 16:37
Knowing FAT32 is far from enough when it comes to flash recovery.
