Page 1 of 1
16gb USB Stick - Problem
Posted: January 25th, 2010, 12:32
by Rousie
Plug the device into the PC, and windows pops up saying it's installing drivers...
Then it fails and tells me it can't install it, and device manager see's it as an unknown device...
It DID work, but for some reason, now it won't.
Not sure of make, as its not branded, and cant see anything on the PCB itself...
Any ideas?
Thanks all,
Dean
Re: 16gb USB Stick - Problem
Posted: July 27th, 2010, 5:42
by Zero Alpha
Just buy a new one.
Posted: July 29th, 2010, 2:20
by granaryloaf
If you want the data and are sufficiently able to rework electronics you could start by checking the crystal. If that is not the problem the controller may have failed.
If that is the case you will need to read the chips directly to get your data back.
Posted: August 4th, 2010, 11:40
by pclab
Have you tried at another pc? same result?
