| 2g USB pen drive "not recognised" http://forum.hddguru.com/viewtopic.php?f=10&t=14964 |
Page 1 of 1 |
| Author: | y23 [ February 27th, 2010, 5:51 ] |
| Post subject: | 2g USB pen drive "not recognised" |
My 2g flash drive has been munged! - Windows does see a usb-device but gives a "Code 10" .. not recognised - Linux lsusb and udev report the stick, but does not give it a /dev/sda node. The blue LED blinks normally, I am stumped. here the gory details: http://y23.com/wiki/pmwiki.php/Main/RecoverySoftware I'd be stoked if anyone helps rescue the day ... |
| Author: | zerocoolorez [ January 19th, 2011, 8:33 ] |
| Post subject: | Re: 2g USB pen drive "not recognised" |
Hi first of all send me an email to fcm4400404@techie.com. Second : Would you like to repair it , or would you like to RIG IT and make it work for a minute to get your data back ? Thankz |
| Author: | y23 [ January 19th, 2011, 19:43 ] |
zerocoolorez wrote: Hi first of all send me an email to fcm4400404@techie.com. Second : Would you like to repair it , or would you like to RIG IT and make it work for a minute to get your data back ? Thankz That would be marvellous, but I can't get at it until April... I'll set myself a alarm and email you then. MERCI |
| Author: | craig6928 [ January 23rd, 2011, 5:23 ] |
is this windows vista your using or windows xp if its windows vista try it in another one code 10 is a windows error code possible drive issue on your machine if not could be the main controller damaged inside the usb pen |
| Author: | zerocoolorez [ January 23rd, 2011, 9:19 ] |
lol |
| Author: | networkpc3000 [ January 23rd, 2011, 21:31 ] |
hi, can you post some images of your FLash drive? have you disconnect it? |
