 Post subject: USB it doesn't work fine
PostPosted: March 23rd, 2010, 19:16
Hello, I have a 16GB flash drive and it doesn't work fine.
When I insert a video will play the first few seconds (until a minute approx.) and then gets stuck.
When I put files. Rar or pdf's me says corrupted file.
I tried using KillDisk, hdd low level format, the tool
windows, etc.. but nothing.
Any help?
Thanks.
 Post subject: Re: USB it doesn't work fine
PostPosted: March 24th, 2010, 4:03
why would you want to killdisk and low hdd your drive
when its a flash drive.
the lag your having is more likely the conversion your using for the video file
or your using the wrong type of conversion processing
post what file format your using
PostPosted: March 24th, 2010, 10:21
Did you scan it for bad sectors ?
data recovery Poland
PostPosted: March 24th, 2010, 10:36
No, how i can do this scan?
PostPosted: March 24th, 2010, 20:24
click on my computer
then right click on the drive itself properties and then tools
as its a flash memory im sure you can scan these for bad sectors as they are ram based not platter based
Users browsing this forum: No registered users and 100 guests
