| USB it doesn't work fine http://forum.hddguru.com/viewtopic.php?f=10&t=15210 |
Page 1 of 1 |
| Author: | krlitoos [ March 23rd, 2010, 19:16 ] |
| Post subject: | USB it doesn't work fine |
Hello, I have a 16GB flash drive and it doesn't work fine. When I insert a video will play the first few seconds (until a minute approx.) and then gets stuck. When I put files. Rar or pdf's me says corrupted file. I tried using KillDisk, hdd low level format, the tool windows, etc.. but nothing. Any help? Thanks. |
| Author: | craig6928 [ March 24th, 2010, 4:03 ] |
| Post subject: | Re: USB it doesn't work fine |
why would you want to killdisk and low hdd your drive when its a flash drive. the lag your having is more likely the conversion your using for the video file or your using the wrong type of conversion processing post what file format your using |
| Author: | laptokowiec [ March 24th, 2010, 10:21 ] |
Did you scan it for bad sectors ? |
| Author: | krlitoos [ March 24th, 2010, 10:36 ] |
No, how i can do this scan? |
| Author: | craig6928 [ March 24th, 2010, 20:24 ] |
click on my computer then right click on the drive itself properties and then tools as its a flash memory im sure you can scan these for bad sectors as they are ram based not platter based |
