Nokia e51 Phonebook Recovery
May 19th, 2010, 3:10
Hi, my nokia e51 just hang on startup did't boot, the solution is to flash the firmware/software, but i will loose all of my contacts, is there any way to recover phonebook ?
thanks
Re: Nokia e51 Phonebook Recovery
May 19th, 2010, 3:25
sounds like corrupt firmware boot up on your phone
try the following
Hold down the green call key, the star key and the 3 key with fingers of one hand, then switch the phone on and keep those buttongs pressed at least until the handshake, this hard-resets the phone.
or if not try this
while phone is switched off, press * and 3 and green button, keep pressed, switch on the phone an wait for the PIN to enter
May 19th, 2010, 3:28
it will not effect the phonebook ?
May 19th, 2010, 9:22
not sure it should not as the phone book might be stored on the phone itself
did you check the sim card ????????
its a reset for the phone
May 19th, 2010, 14:59
I am doing a recovery of the contacts for a client in a Nokia e71.
Afther the client took the phone to the operator.
May 19th, 2010, 20:28
try this program you might get lucky
worth the money allso will work with the nokia e71
http://download.cnet.com/Data-Doctor-Re ... 74914.html
May 20th, 2010, 5:00
It looks a nice program, i did not test it, but can this recovery numbers that are in a SD card.
I have to made a script to search for the header and get all the numbers.
May 20th, 2010, 12:43
i used it and not failed once
but not total sure on sd cards
you can try the below information this has allso helped me in the recovery of some nokia files
The backup is found as \Backup\Backup.arc on the SD card.
allso try and mount the phone in linux
as sometime with some nokia phones it does not like windows os
but as the phone has been back to the phone company
they more likely reflashed the phone and replace the sd card
unless the client did not send back the sd card with the phone
if you see the backup.arc file
then the information is still there.
May 20th, 2010, 12:53
try this other then that i ran out of ideas
you can contacts,text messages, MMS, email etc out of the backup.arc file on the MMC or SD card
http://www.nokisoft.com/
June 3rd, 2010, 13:21
craig6928 thanks for the suggession, it worked but also affect the data.. the phone is now ok.. any ways thanks for help
