EMTEC 1GB
Posted: June 2nd, 2010, 15:40
by laptokowiec
I've got flash drive that has partially damaged PCB (close to USB plug). I don't know model name of it.
I'm looking for PCB photo (both sides) of this drive.
I've seen somewhere similar one, but 2GB. It was C150B model.
Re: EMTEC 1GB
Posted: June 2nd, 2010, 16:13
by arvika
Put your photo. What controller?
Re: EMTEC 1GB
Posted: June 2nd, 2010, 16:42
by drc
Yeah, if you post a photo of what you have, that would help
Re: EMTEC 1GB
Posted: June 3rd, 2010, 6:38
by laptokowiec
Controller UT163. Someone bend it and then tried to repair it.
Don't know where to connect second and third pin (USB plug to pcb).
Re: EMTEC 1GB
Posted: June 3rd, 2010, 6:49
by arvika
Looks like all element on place. Is pen recognize by OS?
If not, you should read flash directly form nand.
Re: EMTEC 1GB
Posted: June 3rd, 2010, 8:51
by fzabkar
laptokowiec wrote:Controller UT163. Someone bend it and then tried to repair it.
Here is a datasheet for the controller:
http://booroo.ru/wp-content/uploads/files/UT163.pdfIt looks like pins 8 and 9 are the USB D+ and D- pins, respectively.
Re: EMTEC 1GB
Posted: June 3rd, 2010, 12:05
by laptokowiec
It's not recognized by OS nor ChipGenius, but the led on it is on (red).
8 and 9. Thanks. I thought so. I'll try and let you know.
Re: EMTEC 1GB
Posted: June 4th, 2010, 2:26
by laptokowiec
Drive is working. Thanks.
