Sandisk Curzer Contour 4GB showing up twice?!
http://forum.hddguru.com/viewtopic.php?f=10&t=16030
Author:  shaun [ June 8th, 2010, 15:00 ]
Post subject:  Sandisk Curzer Contour 4GB showing up twice?!
Hi there,
I have a Sandisk stick here, controller is 20-99-00136-3, flash SDTNLCHSM-4096.
The chip reads fine with soft center's nand reader, but as usual for Sandisk, it's encrypted.
It is detected by the OS, but it shows up twice, as well the USB device as the removable drive entry, both completely empty (not even 0 byte formatted size, but I/O error when tried to access).
Did anyone had this problem so far and found a solution? Is there a Sandisk tool for configuring the controller...?
Author:  pcimage [ June 10th, 2010, 15:54 ]
Post subject:  Re: Sandisk Curzer Contour 4GB showing up twice?!
Sandisk often has a "virtual CD" device in the controller for the hideous S3 software.
