 Post subject: 16gb USB Stick - Problem
PostPosted: January 25th, 2010, 12:32
Plug the device into the PC, and windows pops up saying it's installing drivers...
Then it fails and tells me it can't install it, and device manager see's it as an unknown device...
It DID work, but for some reason, now it won't.
Not sure of make, as its not branded, and cant see anything on the PCB itself...
Any ideas?
Thanks all,
Dean
 Post subject: Re: 16gb USB Stick - Problem
PostPosted: July 27th, 2010, 5:42
Just buy a new one.
Zero Alpha: zeroalpha.com.au
PostPosted: July 29th, 2010, 2:20
If you want the data and are sufficiently able to rework electronics you could start by checking the crystal. If that is not the problem the controller may have failed.
If that is the case you will need to read the chips directly to get your data back.
PostPosted: August 4th, 2010, 11:40
Have you tried at another pc? same result?
ACELab partner
Users browsing this forum: Abdul Rauf and 76 guests
