4 GB CompactFlash shows up as "137 GB" Flash
Posted: October 6th, 2010, 6:53
Hello everybody,
I am using a 4 GB CompctFlash in a small computer system instead of a HDD. Everything works fine.
The the system crashed (problkem of the operating system) and I wanted to reinstall everything. But the CompactFlash is not accessible anymore.
Windows says, it is a 128 GB Card (not true). If I want to format it, it does not work (of course, Windows expects 128 GB, but there are just 4 GB).
So, the Card can not even "remember" how much memory it has...
I tried to perform a LowLevelFormat with the tool on this website. The card was identified as "137,43 GB". The LowLevelFormat was done without any errors. But then still the same: I can nou use the card.
Is there a possibility, to set the card back to a working state?
I think, there is a memory inside, which tells the controller how big is the capacity - and this data seems to be corrupted.
Thank you for your help!
