microSD (1GB) with a password set by a Nokia phone,how wipe?
http://forum.hddguru.com/viewtopic.php?f=10&t=17535
Author:  ale5000 [ November 2nd, 2010, 7:54 ]
Post subject:  microSD (1GB) with a password set by a Nokia phone,how wipe?
I have a microSD (1GB) with a password set by a Nokia phone, datas aren't important.
If I insert it in the Nokia phone it can be read/write and even formatted (but it still protected after this), instead if I insert it in the card reader or in other phones it isn't recognized.
There is a way to force a card reader to ignore the "status" and wipe out everything?
Or there is a special card reader that support these things?
Author:  HDDKitteh [ November 11th, 2010, 14:32 ]
Post subject:  Re: microSD (1GB) with a password set by a Nokia phone,how wipe?
I wasn't even aware that microSD cards could be password protected. I guess this proves just how much of a n00b I am. I suppose if you're having difficulty altering the contents of the card (without a password), you aught to call up the manufacturer or bring it to a professional. Many of them can follow a procedure/shortcut that will eliminate the password factor.
Author:  DPB [ February 4th, 2011, 6:14 ]
You need to insert the MicroSD card back into the Nokia phone then decrypt/remove it's password. Considering you still have the phone.
Author:  ale5000 [ February 4th, 2011, 22:38 ]
I have the phone but not the password.
Author:  craig6928 [ February 12th, 2011, 6:42 ]
if you can update the nokia phone software and have the cables
it will reset the password to default
12345 or 00000
then you can format it
Author:  frantel [ April 7th, 2011, 12:59 ]
in phone is file wich contain password. i cant remember filename. try google.
Author:  gopalg73 [ September 5th, 2011, 22:18 ]
hi , next time put card in another nokia e series phone, eg e90, e71, e72 etc and format the card, then recover data.
it works 100%.
regards
gopal
