| Having trouble with deleted files recovery... Please help.. http://forum.hddguru.com/viewtopic.php?f=10&t=17808 |
Page 1 of 1 |
| Author: | dick [ November 29th, 2010, 8:54 ] |
| Post subject: | Re: Having trouble with deleted files recovery... Please help.. |
Hi, It seems some of the files might have already been overwritten. If I were you I would create a complete image of your memory device and save it as a file. Then you can work on the file and try and compare different applications to recover the data. |
| Author: | mihaelozg [ November 29th, 2010, 9:02 ] |
Quote: Hi, It seems some of the files might have already been overwritten. If I were you I would create a complete image of your memory device and save it as a file. Then you can work on the file and try and compare different applications to recover the data. hm.. how to create image? And which application to use then? Thank you! |
| Author: | laptokowiec [ November 29th, 2010, 15:22 ] |
DMDE, R-Studio, WinHex |
