 Post subject: 2g USB pen drive "not recognised"
PostPosted: February 27th, 2010, 5:51
My 2g flash drive has been munged!
- Windows does see a usb-device but gives a "Code 10" .. not recognised
- Linux lsusb and udev report the stick, but does not give it a /dev/sda node.
The blue LED blinks normally, I am stumped.
here the gory details:
http://y23.com/wiki/pmwiki.php/Main/RecoverySoftware
I'd be stoked if anyone helps rescue the day ...
 Post subject: Re: 2g USB pen drive "not recognised"
PostPosted: January 19th, 2011, 8:33
Hi first of all send me an email to fcm4400404@techie.com.
Second : Would you like to repair it , or would you like to RIG IT and make it work for a minute to get your data back ?
Thankz :)
PostPosted: January 19th, 2011, 19:43
Thankz :)
That would be marvellous, but I can't get at it until April... I'll set myself a alarm and email you then. MERCI
PostPosted: January 23rd, 2011, 5:23
is this windows vista your using or windows xp
if its windows vista try it in another one
code 10 is a windows error code
possible drive issue on your machine
if not could be the main controller damaged inside the usb pen
PostPosted: January 23rd, 2011, 9:19
lol
PostPosted: January 23rd, 2011, 21:31
hi,
can you post some images of your FLash drive? have you disconnect it?
data recovery service[/b]
