| Data recovery from defective ADATA N005 16G http://forum.hddguru.com/viewtopic.php?f=10&t=19362 |
Page 1 of 1 |
| Author: | ptrk.mj [ May 11th, 2011, 7:58 ] |
| Post subject: | Data recovery from defective ADATA N005 16G |
Hello. My flash drive went crazy. Partitions are wiped out. There are no entries inside MBR partition table. MBR signature is set to 4A55. It reports 4 GB capacity to Windows' XP Logical Disk Manager. It reports 8,388,605 logical sectors to DMDE. I contacted ADATA service support but they just told me that my flash drive is defective and I should swap it for a new one. However, they didn't mention a thing about data recovery, and I need my data very badly! Any suggestions? ptrkmj |
| Author: | ptrk.mj [ May 11th, 2011, 8:26 ] |
| Post subject: | Re: Data recovery from defective ADATA N005 16G |
I forgot to mention that every logical sector has the same content as sector 0, that is: http://i55.tinypic.com/2heysg6.png |
| Author: | DR-Kiev [ May 11th, 2011, 15:29 ] |
ptrk.mj wrote: I forgot to mention that every logical sector has the same content as sector 0, that is: http://i55.tinypic.com/2heysg6.png Looks like controller got crazy. It shows you tech-data. Need to read Nand's chips dirrectly via Flash-reader. If your data is very important, contact with Data Recovery experts near you for help. |
| Author: | ptrk.mj [ May 12th, 2011, 7:48 ] |
DR-Kiev wrote: Need to read Nand's chips dirrectly via Flash-reader. Can't I just buy such Flash-reader and do it myself? However, that might break my warranty. |
| Author: | hddguy [ May 12th, 2011, 7:55 ] |
The cost and time / training that is required is way too high for a single case. You should consider somebody who already has the right tools and skills |
| Author: | pcimage [ May 12th, 2011, 8:32 ] |
ptrk.mj wrote: DR-Kiev wrote: Need to read Nand's chips dirrectly via Flash-reader. Can't I just buy such Flash-reader and do it myself? However, that might break my warranty. Maybe but consider: 1. Cost of NAND reader - $210 2. Cost of software - $1870 3. Learning of how to use it - 3 months absolute minimum Frankly if you care more for warranty on a $40 device than the data, then I don't think so!! |
