 Post subject: Data recovery from defective ADATA N005 16G
PostPosted: May 11th, 2011, 7:58
Hello.
My flash drive went crazy.
Partitions are wiped out. There are no entries inside MBR partition table. MBR signature is set to 4A55. It reports 4 GB capacity to Windows' XP Logical Disk Manager. It reports 8,388,605 logical sectors to DMDE.
I contacted ADATA service support but they just told me that my flash drive is defective and I should swap it for a new one. However, they didn't mention a thing about data recovery, and I need my data very badly!
Any suggestions?
ptrkmj
 Post subject: Re: Data recovery from defective ADATA N005 16G
PostPosted: May 11th, 2011, 8:26
I forgot to mention that every logical sector has the same content as sector 0, that is:
http://i55.tinypic.com/2heysg6.png
PostPosted: May 11th, 2011, 15:29
Looks like controller got crazy. It shows you tech-data.
Need to read Nand's chips dirrectly via Flash-reader.
If your data is very important, contact with Data Recovery experts near you for help.
Angel Data Recovery
PostPosted: May 12th, 2011, 7:48
Can't I just buy such Flash-reader and do it myself?
However, that might break my warranty.
PostPosted: May 12th, 2011, 7:55
The cost and time / training that is required is way too high for a single case.
You should consider somebody who already has the right tools and skills
PostPosted: May 12th, 2011, 8:32
Maybe but consider:
1. Cost of NAND reader - $210
2. Cost of software - $1870
3. Learning of how to use it - 3 months absolute minimum
Frankly if you care more for warranty on a $40 device than the data, then I don't think so!!
