 Post subject: 2 diode burnt?
PostPosted: May 31st, 2011, 17:22
from this 1 gb pen drive there was a burnt strong smell.
i opened and i found the (diode?) burnt
a) C14
b) no text but it's possible to see from the pictures.
Any idea if both are simple diode?
 Post subject: Re: 2 diode burnt?
PostPosted: May 31st, 2011, 17:50
you can try and buy an identical one and try swapping the bad diodes (assuming that no other diode/resistor is bad), or you can send to a professional. a professional will probably only charge 200-300 to extract the data from the chip manually.
PostPosted: May 31st, 2011, 17:53
hi - did u try to enlarge the pictures, are u sure they are just diode ?
it's a no-name pen drive so i would like to shortcut them (assuming that a bad usb port made this burn - and that they are diode)
PostPosted: May 31st, 2011, 18:07
a) C14
Hint - a diode PCB marking would not start with "C" :)
I would trace the PCB tracks to identify the likely function of that component - but it looks the same type as "C14".
Not diodes - at least not "C14"; I would need to spend more time tracing the PCB to check the other burned component. Do NOT short-circuit them, as you suggest later.
What does the customer say was the cause - was there a possible overvoltage?
PostPosted: May 31st, 2011, 23:19
I agree with Vulcan regarding the circuit tracing.
Usually when an electrolytic capacitor fails catastrophically, the cause is an overvoltage, or reverse polarity. There appears to be a 3.3V linear regulator (U6) between the USB port and the controller and flash memory. Hopefully it will have limited the damage. I can't read its markings, but a typical pinout would be Input (+5V) - Ground - Output (+3.3V). I would clean the affected area with a toothbrush and isopropyl alcohol.
Datasheets:
OTi-2168, Ours Technology Inc., USB 2.0 FLASH DISK CONTROLLER, 3.3V:
http://www.datasheetarchive.com/pdf/get ... pdf&scan=n
K9W8G08U1M, Samsung, 3.3V, 512M x 8 Bit / 256M x 16 Bit NAND Flash Memory:
http://www.datasheetcatalog.org/datashe ... 215_DS.pdf
PostPosted: June 6th, 2011, 0:50
i can handle this case. do you need any help?
data recovery service[/b]
Users browsing this forum: No registered users and 31 guests
