 Post subject: ODF recovery from Flash
PostPosted: June 21st, 2011, 10:09
Got an upset student, the document she needs is on a flash drive.
Got everything off it and 90% opens including images.
The main thing she needs has been done in open office (ODF) However it is blank on Openoffice and Word.
Ran Kernel for ODF on it but no go, the hex for the file is fairly chunky tho. The file itself is 223kb
any ideas?
thanks
andy
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
 Post subject: Re: ODF recovery from Flash
PostPosted: June 21st, 2011, 10:56
buster80 wrote:
any ideas?
What was the problem diagnosed with the USB stick - logical (filesystem) corruption only or unreadable blocks or ...? Any possibility of earlier versions of the file on a PC anywhere, where the doc was prevously edited? Consider raw text extraction if the file format is too corrupted for it to be recognised natively? Look in the USB stick free space for earlier copies?
PostPosted: June 21st, 2011, 11:03
OpenOffice typically saves raw text in a zipped xml format, so the raw text will not be visible in hex viewer etc
However if you can locate and carve the relevant zipped xml (content.xml) data then you can rebuild a .zip file for it and extract the text
PostPosted: June 21st, 2011, 11:11
Good point :) - it was the OP's mention of Word that got me into typical "Word" mindset... The OP hasn't said what file format was actually used - was it really an odt? We haven't been told. It would be nice if the OP showed some of the hex dump they were looking at, IMHO.
PostPosted: June 21st, 2011, 11:15
I was just going off of this
PostPosted: June 21st, 2011, 11:27
@drc:
Sure, understood. :) I just know several people who use OpenOffice at home, saving into normal Word .doc files, so that they can read the same file on systems running MS Word at the office / university etc. - hence why I took the OP's mention of Word in that way.
PostPosted: June 21st, 2011, 11:53
thanks guys, its a head scratcher
Users browsing this forum: Zeelo99 and 24 guests
