| USB Flash Problem | The disk in the drive cannot be formated http://forum.hddguru.com/viewtopic.php?f=10&t=19937 |
Page 1 of 1 |
| Author: | shahn [ July 8th, 2011, 7:45 ] |
| Post subject: | USB Flash Problem | The disk in the drive cannot be formated |
My USB Flash Drive (4 GB Transcend JetFlash V30) was working fine since 3 years. Yesterday when i plugged it in, its not accessible its not even showing the memory capacity. windows said this disk in the dirve is not formatted then when i click format it says the disk in the drive cannot be formatted. ![]() I tried many tools like HP Storage Format tool, and many others from Hiren Boot CD but nothing helped.. i have also tried HDD low level format tool from HDDguru but no use.. I have included error msg pic of HDD LL format tool below.. ![]() Please provide any solution for this. |
| Author: | drc [ July 8th, 2011, 10:36 ] |
| Post subject: | Re: USB Flash Problem | The disk in the drive cannot be form |
If you're not trying to recover data, just bin it and get a new one |
| Author: | shahn [ July 8th, 2011, 10:39 ] |
is there any way to fix this problem or not? |
| Author: | pcimage [ July 8th, 2011, 12:08 ] |
No. Well, not without spend 100x more than it would cost to buy a new one. If you don't want the data, then do as drc says and bin it. |
