 Post subject: Sandisk Memory Stick pro duo 4gb
PostPosted: September 7th, 2011, 15:34
Hi all.
A friend of mine removed this card from camera when it was on. Now windows recognizes the card but asks to format it and R-studio detect it as a memory of 238.25mb. This is the log from secinspect:
Target - \\.\PHYSICALDRIVE4
30 Cylinders
255 Heads
63 Sectors Per Track
512 BytesPerSector
11 MediaType
Master Boot Record
| B | FS TYPE | START | END | | |
| F | (hex) | C H S| C H S| RELATIVE | TOTAL |
| | 00 | 0 0 0| 0 0 0| 0| 0|
Disk Signature 0x00000000
LBN 0 [C 0, H 0, S 1]
0x0000 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0010 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0020 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0030 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0040 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0050 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0060 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0070 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0080 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0090 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00a0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00b0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00c0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00d0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00e0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x00f0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0100 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0110 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0120 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0130 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0140 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0150 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0160 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0170 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0180 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x0190 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01a0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01b0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01c0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01d0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01e0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
0x01f0 00 00 00 00 00 00 00 00-00 00 00 00 00 00 00 00 ................
Bad view! Any chance to recover the pictures?
Thanks in advance
gabriele
 Post subject: Re: Sandisk Memory Stick pro duo 4gb
PostPosted: September 22nd, 2011, 19:59
If you can't read all its sectors then it has a hardware fault. Time to start making calls.
Zero Alpha: zeroalpha.com.au
PostPosted: September 23rd, 2011, 4:44
In R-Studio, in the hex view option, when you scroll through the entire device, do you data? Or all zeros?
May your friend have accidently attempted to format, wipe or erase the card?
PostPosted: September 23rd, 2011, 5:08
This is beyond any DIY repairs.
It is also likely that this is monolithic device also. Maybe you are lucky and will be 8 bit device, then chance of recovery in professional lab is high.
PostPosted: September 24th, 2011, 2:30
this might be Controller issue
you will need Proper tools
Users browsing this forum: No registered users and 126 guests
