 Post subject: OCZ Vertex2 40gb not visible in BIOS
PostPosted: October 20th, 2011, 15:42
Good afternoon. help cure OCZ Vertex2 40gb. After rebooting the SSD is not visible in the BIOS. I found the information that you can run a jumper it in safe mode and flash fails, the utility did not see SSD. The board has 3 LEDs. When the light is turned green and when you try to access the SSD light up red. On experience with flash drives, short contacts on the chip on a hot b tossed to SATA SSD determined and immediately disappeared from the system, blue LED lights up and is now with the lights green and blue. Plug your terminal:
CLI> PINRST
*** ROM 106 Mar 12 2009 20:29:35 ***
FW_SRC 0 SHA PASS!
*** EEPROM 202 Apr 30 2010 16:53:54 BuildServer:FW_Common_Critical_Fixes:FW_Comm
on_Build_Release-247324 ***
Micron Timing EPch
*** Patch 1.4.1 Sep 20 2010 13:33:48 BuildServer:FW_Common_Critical_Fixes:P1_3_3
_L_Drop-270756 ***
Micron Timing EPch
RCPch SAK0
ÿÿÿÿÿ\_ýÞýÞýÞø^(_ýÞýÞýÞm—ŒýÞÿÿÿÿìcýÞýÞýÞýÞýÞýÞÂvÄ1ýÞUdP‡
ýÞýÞýÞÿÿÿÕýÞýÞÕýÞýÞ
ýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞþ‚ýÞþ€ýÞýÞýÞ ‹IàýÞUdp‡
ýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞþ‚ýÞþ€ýÞýÞýÞXŠ&ýÞUdȇ
on a lot of garbage. If you turn not to consider him the information from the flash (SPI) in the terminal gives
CLI> PINRST
_L_Drop-270756 ***
RCPch SAK0
Failed to read EPA=20038060, using ByteLaneMask=2, ByteLaneTable[0]=1
Failed to read EPA=20038060, using ByteLaneMask=1, ByteLaneTable[1]=0
Failed to read EPA=20038060, using ByteLaneMask=4, ByteLaneTable[2]=2
RCPch SHI
sysclk 150 MHz
JTAG En 0
Link ...
in this case if you connect it to your computer after long reflection, it appears in the BIOS, but SandForce 25gb. OS does not boot (even with the Linux boot loader office site is loaded but the utility does not see SSD). On hot in Windows is defined as the SandForce drive. Tell me how or where to read how to pick it up. Maybe someone can merge dump of SPI?
P.S. Sorry for the bad English.
 Post subject: Re: OCZ Vertex2 40gb not visible in BIOS
PostPosted: October 21st, 2011, 4:23
Get this professionally diagnosed.
Sandforce use Encryption so the only option to save your data is to have the device professionally repaired, if it is possible.
PostPosted: October 21st, 2011, 5:01
Thanks for the advice, but I do not need information. I want to repair it yourself
PostPosted: August 17th, 2013, 15:38
PM sent.
Angel Data Recovery
PostPosted: August 17th, 2013, 15:39
@loiren, I would very much like to explore the voltage test points on the PCB. Do you have a multimeter, and would you be prepared to make some measurements?
If so, then please upload detailed photos of both sides of the PCB.
PostPosted: December 7th, 2014, 15:31
DR-Kiev,
Здравствуйте, у меня такая же проблема с SSD диском, можно и мне подсказать рецепт исцеления данной железки?
PostPosted: December 8th, 2014, 20:17
a big mistake in embedded systems is assuming that output that is not human readable is "garbage"
read here on that "garbage" http://www.eevblog.com/forum/repair/ocz-vertex-2-ssd-firmware/
for what its worth, in this situation googling for
RCPch SAK0
should have been in the top 3 things to do.
this is Sandforce, the bane of DR engineers.
PostPosted: December 8th, 2014, 23:35
another link that may be of interest, though not 100% related to the thread:
http://www.overclock.net/t/1330730/ocz-firmware-2-25-trim-doesnt-work-bug-regression-bad-ocz-experience
on another note, this is interesting from the link I posted earlier..:
CLI> PINRST
*** Patch 1.4.1 Apr 8 2011 00:55:09 BuildServer:P1_3_6_1_MP4_Patch1_20110408:P1_3_6_1_MP4_Patch1_20110408-305073 ***
RCPch SAK0+Fmgr
Failed to read EPA=200800C0, using ByteLaneMask=2, ByteLaneTable[0]=1
Failed to read EPA=200800C0, using ByteLaneMask=4, ByteLaneTable[1]=2
Failed to read EPA=200800C0, using ByteLaneMask=1, ByteLaneTable[2]=0
Failed to read EPA=200800C0, using ByteLaneMask=8, ByteLaneTable[3]=3
RCPch SHI
sysclk 150 MHz
JTAG En 0
Link ...
up
in particular:
JTAG En 0
would this turn JTAG functionality off? and would it be pssible to re-enable it in Terminal or by hacking the firmware and editing a start-up script?
Users browsing this forum: Google [Bot] and 132 guests
