| OCZ Vertex2 40gb not visible in BIOS http://forum.hddguru.com/viewtopic.php?f=10&t=20882 |
Page 1 of 1 |
| Author: | loiren [ October 20th, 2011, 15:42 ] |
| Post subject: | OCZ Vertex2 40gb not visible in BIOS |
Good afternoon. help cure OCZ Vertex2 40gb. After rebooting the SSD is not visible in the BIOS. I found the information that you can run a jumper it in safe mode and flash fails, the utility did not see SSD. The board has 3 LEDs. When the light is turned green and when you try to access the SSD light up red. On experience with flash drives, short contacts on the chip on a hot b tossed to SATA SSD determined and immediately disappeared from the system, blue LED lights up and is now with the lights green and blue. Plug your terminal: CLI> PINRST *** ROM 106 Mar 12 2009 20:29:35 *** FW_SRC 0 SHA PASS! *** EEPROM 202 Apr 30 2010 16:53:54 BuildServer:FW_Common_Critical_Fixes:FW_Comm on_Build_Release-247324 *** Micron Timing EPch *** Patch 1.4.1 Sep 20 2010 13:33:48 BuildServer:FW_Common_Critical_Fixes:P1_3_3 _L_Drop-270756 *** Micron Timing EPch RCPch SAK0 ÿÿÿÿÿ\_ýÞýÞýÞø^(_ýÞýÞýÞm—ŒýÞÿÿÿÿìcýÞýÞýÞýÞýÞýÞÂvÄ1ýÞUdP‡ ýÞýÞýÞÿÿÿÕýÞýÞÕýÞýÞ ýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞþ‚ýÞþ€ýÞýÞýÞ ‹IàýÞUdp‡ ýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞ ýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞþ‚ýÞþ€ýÞýÞýÞXŠ&ýÞUdȇ ýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞýÞý on a lot of garbage. If you turn not to consider him the information from the flash (SPI) in the terminal gives CLI> PINRST *** ROM 106 Mar 12 2009 20:29:35 *** *** Patch 1.4.1 Sep 20 2010 13:33:48 BuildServer:FW_Common_Critical_Fixes:P1_3_3 _L_Drop-270756 *** RCPch SAK0 Failed to read EPA=20038060, using ByteLaneMask=2, ByteLaneTable[0]=1 Failed to read EPA=20038060, using ByteLaneMask=1, ByteLaneTable[1]=0 Failed to read EPA=20038060, using ByteLaneMask=4, ByteLaneTable[2]=2 RCPch SHI sysclk 150 MHz JTAG En 0 Link ... in this case if you connect it to your computer after long reflection, it appears in the BIOS, but SandForce 25gb. OS does not boot (even with the Linux boot loader office site is loaded but the utility does not see SSD). On hot in Windows is defined as the SandForce drive. Tell me how or where to read how to pick it up. Maybe someone can merge dump of SPI? P.S. Sorry for the bad English. |
| Author: | hddguy [ October 21st, 2011, 4:23 ] |
| Post subject: | Re: OCZ Vertex2 40gb not visible in BIOS |
Get this professionally diagnosed. Sandforce use Encryption so the only option to save your data is to have the device professionally repaired, if it is possible. |
| Author: | loiren [ October 21st, 2011, 5:01 ] |
Thanks for the advice, but I do not need information. I want to repair it yourself |
| Author: | DR-Kiev [ August 17th, 2013, 15:38 ] |
loiren wrote: Thanks for the advice, but I do not need information. I want to repair it yourself PM sent. |
| Author: | fzabkar [ August 17th, 2013, 15:39 ] |
@loiren, I would very much like to explore the voltage test points on the PCB. Do you have a multimeter, and would you be prepared to make some measurements? If so, then please upload detailed photos of both sides of the PCB. |
| Author: | g1obus [ December 7th, 2014, 15:31 ] |
DR-Kiev, Здравствуйте, у меня такая же проблема с SSD диском, можно и мне подсказать рецепт исцеления данной железки? |
| Author: | HaQue [ December 8th, 2014, 20:17 ] |
a big mistake in embedded systems is assuming that output that is not human readable is "garbage" read here on that "garbage" http://www.eevblog.com/forum/repair/ocz-vertex-2-ssd-firmware/ for what its worth, in this situation googling for Code: RCPch SAK0 should have been in the top 3 things to do.this is Sandforce, the bane of DR engineers. |
| Author: | HaQue [ December 8th, 2014, 23:35 ] |
another link that may be of interest, though not 100% related to the thread: http://www.overclock.net/t/1330730/ocz-firmware-2-25-trim-doesnt-work-bug-regression-bad-ocz-experience on another note, this is interesting from the link I posted earlier..: Quote: CLI> PINRST *** ROM 106 Mar 12 2009 20:29:35 *** *** Patch 1.4.1 Apr 8 2011 00:55:09 BuildServer:P1_3_6_1_MP4_Patch1_20110408:P1_3_6_1_MP4_Patch1_20110408-305073 *** RCPch SAK0+Fmgr Failed to read EPA=200800C0, using ByteLaneMask=2, ByteLaneTable[0]=1 Failed to read EPA=200800C0, using ByteLaneMask=4, ByteLaneTable[1]=2 Failed to read EPA=200800C0, using ByteLaneMask=1, ByteLaneTable[2]=0 Failed to read EPA=200800C0, using ByteLaneMask=8, ByteLaneTable[3]=3 RCPch SHI sysclk 150 MHz JTAG En 0 Link ... up in particular: Quote: JTAG En 0 would this turn JTAG functionality off? and would it be pssible to re-enable it in Terminal or by hacking the firmware and editing a start-up script? |
