 Post subject: USB Memory Stick not detected
PostPosted: December 5th, 2011, 10:39
Hi guys,
Haven't done much work on USBs so I'd thought i'd ask for your input.
- 4GB usb stick.
- PC does not detect any USB nor does the LED light up.
- No obvious burn marks.
- All fuses seem intact.
- Possible crystal oscillator?
Any suggestions?
Thanks in advance.
DR
 Post subject: Re: USB Memory Stick not detected
PostPosted: December 5th, 2011, 10:56
This would by my guess, but accurate diagnosis is near impossible without seeing the media
PostPosted: December 5th, 2011, 11:54
Would also be my first try. Easy to test with an osciloscope !
If the oscillator is working, then my guess would be the controler and you'll have to work on the memory chip !
Lemmy
PostPosted: December 5th, 2011, 14:55
@DanR:
It may be helpful to know the history of that USB drive, leading to the current situation.
PostPosted: December 5th, 2011, 16:48
@Vulcan
Unsure of history but there have been no previous DR attempts. Plug USB into computer and you get nothing.
@ici_lemmy
Tested using an oscilloscope. Was showing no 12MHz, so I presumed it dead. Replaced the crystal and still no 12MHz output. This leads me to think that the micro-controller is now dead.
PostPosted: December 5th, 2011, 16:53
DanR wrote:
@Vulcan
@ici_lemmy
In which case you'll need to remove the flash chip, read it in and reconstruct the data.
PostPosted: December 5th, 2011, 17:20
@DanR:
Thanks for the reply.
DanR wrote:
Unsure of history
That's a shame for you, as having that info often helps troubleshooting, in my experience.
There can be other reasons for your reported measurement, not only a dead controller.
As you've already seen, pcimage has explained a classic DR approach, if you are unable to repair the original USB drive.
Good luck!
PostPosted: December 6th, 2011, 7:14
Taking the chips down to the lab tomorrow. Will post results (if any)
PostPosted: December 6th, 2011, 11:27
There is no reason that the memory chip is dead. So you will have result but the difficult part is to reconstruct the data...
Lemmy
PostPosted: December 6th, 2011, 13:35
Before doing anything drastic I would also always check the 4 contacts from the usb connector to the pcb for continuity. And it is a good idea to check for +5v and then check the +/- data lines to the controller.
PostPosted: December 7th, 2011, 21:43
Can you measure any voltage on the memory chip's Vcc pin(s)?
Is there a discrete 3.3V linear regulator IC on the PCB?
Users browsing this forum: No registered users and 17 guests
