 Post subject: wet pendrive
PostPosted: December 22nd, 2011, 4:06
Hi all,
According to your experience, it's possible recovery data from a flash memory after going through the washer? The chip is damaged? I could try with PC3000 flash
 Post subject: Re: wet pendrive
PostPosted: December 22nd, 2011, 10:47
Damaged how? The chip itself is cracked? The chip's legs are broken?
Posting a picture may help a lot.
PostPosted: December 22nd, 2011, 12:30
cat1x wrote:
Hi all,
it is possible, i don`t think the washer will break the chip, it is strong compared to hdd hhehe
PostPosted: December 23rd, 2011, 5:24
the NAND chips of many Flash devices are coated in a sort of silicone to allow some degree of water resistance. Also, the water should not directly damage the NAND only potentially oxidise the connections.
Data should be recoverable, though this may only possible with a professional recovery service.
PostPosted: December 23rd, 2011, 6:24
Is not possible because I don't have the pendrive in my hands
Thanks guys, this is I want know
