Recovering pendrive after crash
Posted: January 6th, 2012, 4:58
Hello, I have a emtec 16gb which was crashed and since then was undetected by operative system, and pendrive was dead.
While I was measuring voltages, led turned on intermitently. Now the pendrive is detected by operative system but doesn't can mount the filesystem, although is tried again and again, as you can see (GNU/Linux):
If I try mounting it manually, I get this errors:
Do you think the problem is the controller, or the filesystem corruption? If it's possible, I can repair it before a flash chip removing and data reconstruction.
- Code:
[ 711.844912] usb-storage: device found at 33
[ 711.844915] usb-storage: waiting for device to settle before scanning
[ 716.840346] usb-storage: device scan complete
[ 716.880448] scsi 31:0:0:0: Direct-Access USB DISK 2.0 PMAP PQ: 0 ANSI: 0 CCS
[ 716.881777] sd 31:0:0:0: Attached scsi generic sg2 type 0
[ 725.948273] sd 31:0:0:0: [sdd] 31277056 512-byte logical blocks: (16.0 GB/14.9 GiB)
[ 725.948756] sd 31:0:0:0: [sdd] Write Protect is off
[ 725.948763] sd 31:0:0:0: [sdd] Mode Sense: 23 00 00 00
[ 725.948769] sd 31:0:0:0: [sdd] Assuming drive cache: write through
[ 725.951631] sd 31:0:0:0: [sdd] Assuming drive cache: write through
[ 725.951640] sdd: sdd1
[ 725.988139] sd 31:0:0:0: [sdd] Assuming drive cache: write through
[ 725.988149] sd 31:0:0:0: [sdd] Attached SCSI removable disk
[ 825.836190] usb 1-1: USB disconnect, address 33
[ 825.840127] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.840133] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.840141] end_request: I/O error, dev sdd, sector 6036528
[ 825.840149] __ratelimit: 374 callbacks suppressed
[ 825.840156] Buffer I/O error on device sdd1, logical block 6028464
[ 825.840161] lost page write due to I/O error on sdd1
[ 825.840167] Buffer I/O error on device sdd1, logical block 6028465
[ 825.840172] lost page write due to I/O error on sdd1
[ 825.840178] Buffer I/O error on device sdd1, logical block 6028466
[ 825.840183] lost page write due to I/O error on sdd1
[ 825.840189] Buffer I/O error on device sdd1, logical block 6028467
[ 825.840194] lost page write due to I/O error on sdd1
[ 825.840199] Buffer I/O error on device sdd1, logical block 6028468
[ 825.840204] lost page write due to I/O error on sdd1
[ 825.840210] Buffer I/O error on device sdd1, logical block 6028469
[ 825.840215] lost page write due to I/O error on sdd1
[ 825.840220] Buffer I/O error on device sdd1, logical block 6028470
[ 825.840225] lost page write due to I/O error on sdd1
[ 825.840231] Buffer I/O error on device sdd1, logical block 6028471
[ 825.840236] lost page write due to I/O error on sdd1
[ 825.840243] Buffer I/O error on device sdd1, logical block 6028472
[ 825.840248] lost page write due to I/O error on sdd1
[ 825.840254] Buffer I/O error on device sdd1, logical block 6028473
[ 825.840259] lost page write due to I/O error on sdd1
[ 825.840465] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.840470] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.840477] end_request: I/O error, dev sdd, sector 6036656
[ 825.840694] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.840698] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.840705] end_request: I/O error, dev sdd, sector 6036784
[ 825.840918] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.840923] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.840930] end_request: I/O error, dev sdd, sector 6036912
[ 825.841146] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.841151] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.841158] end_request: I/O error, dev sdd, sector 6037040
[ 825.841416] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.841421] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.841428] end_request: I/O error, dev sdd, sector 6037168
[ 825.841649] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.841654] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.841661] end_request: I/O error, dev sdd, sector 6037296
[ 825.841874] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.841879] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.841886] end_request: I/O error, dev sdd, sector 6037424
[ 825.842097] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.842102] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.842109] end_request: I/O error, dev sdd, sector 6037552
[ 825.842319] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.842324] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.842331] end_request: I/O error, dev sdd, sector 6037680
[ 825.842542] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.842547] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.842554] end_request: I/O error, dev sdd, sector 6037808
[ 825.842766] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.842771] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.842778] end_request: I/O error, dev sdd, sector 6037936
[ 825.842990] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.842995] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.843002] end_request: I/O error, dev sdd, sector 6038064
[ 825.843214] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.843219] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.843225] end_request: I/O error, dev sdd, sector 6038192
[ 825.843442] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.843447] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.843454] end_request: I/O error, dev sdd, sector 6038320
[ 825.843667] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.843671] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.843678] end_request: I/O error, dev sdd, sector 6038448
[ 825.843897] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.843902] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.843909] end_request: I/O error, dev sdd, sector 6038576
[ 825.844146] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.844151] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.844158] end_request: I/O error, dev sdd, sector 6038704
[ 825.844375] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.844380] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.844386] end_request: I/O error, dev sdd, sector 6038832
[ 825.844597] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.844602] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.844609] end_request: I/O error, dev sdd, sector 6038960
[ 825.844817] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.844822] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.844829] end_request: I/O error, dev sdd, sector 6039088
[ 825.845052] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.845057] sd 31:0:0:0: [sdd] Result: hostbyte=DID_ERROR driverbyte=DRIVER_OK
[ 825.845064] end_request: I/O error, dev sdd, sector 6039216
[ 825.861087] sd 31:0:0:0: [sdd] Unhandled error code
[ 825.861096] sd 31:0:0:0: [sdd] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[ 825.861104] end_request: I/O error, dev sdd, sector 6039344
[ 826.325073] usb 1-1: new high speed USB device using ehci_hcd and address 34
[ 826.459809] usb 1-1: configuration #1 chosen from 1 choice
[ 826.465298] scsi32 : SCSI emulation for USB Mass Storage devices
[ 826.465552] usb-storage: device found at 34
[ 826.465556] usb-storage: waiting for device to settle before scanning
[ 831.464356] usb-storage: device scan complete
[ 831.504958] scsi 32:0:0:0: Direct-Access USB DISK 2.0 PMAP PQ: 0 ANSI: 0 CCS
[ 831.506272] sd 32:0:0:0: Attached scsi generic sg2 type 0
[ 840.396165] sd 32:0:0:0: [sde] 31277056 512-byte logical blocks: (16.0 GB/14.9 GiB)
[ 840.396645] sd 32:0:0:0: [sde] Write Protect is off
[ 840.396652] sd 32:0:0:0: [sde] Mode Sense: 23 00 00 00
[ 840.396657] sd 32:0:0:0: [sde] Assuming drive cache: write through
[ 840.399895] sd 32:0:0:0: [sde] Assuming drive cache: write through
[ 840.399904] sde: sde1
[ 840.437394] sd 32:0:0:0: [sde] Assuming drive cache: write through
[ 840.437404] sd 32:0:0:0: [sde] Attached SCSI removable disk
[ 913.224692] usb 1-1: USB disconnect, address 34
[ 913.228906] sd 32:0:0:0: [sde] Unhandled error code
[ 913.228913] sd 32:0:0:0: [sde] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[ 913.228921] end_request: I/O error, dev sde, sector 6036528
[ 913.228929] __ratelimit: 2934 callbacks suppressed
[ 913.228936] Buffer I/O error on device sde1, logical block 6028464
[ 913.228941] lost page write due to I/O error on sde1
[ 913.228948] Buffer I/O error on device sde1, logical block 6028465
[ 913.228953] lost page write due to I/O error on sde1
[ 913.228959] Buffer I/O error on device sde1, logical block 6028466
[ 913.228964] lost page write due to I/O error on sde1
[ 913.228969] Buffer I/O error on device sde1, logical block 6028467
[ 913.228974] lost page write due to I/O error on sde1
[ 913.228980] Buffer I/O error on device sde1, logical block 6028468
[ 913.228985] lost page write due to I/O error on sde1
[ 913.228991] Buffer I/O error on device sde1, logical block 6028469
[ 913.228996] lost page write due to I/O error on sde1
[ 913.229001] Buffer I/O error on device sde1, logical block 6028470
[ 913.229006] lost page write due to I/O error on sde1
[ 913.229012] Buffer I/O error on device sde1, logical block 6028471
[ 913.229017] lost page write due to I/O error on sde1
[ 913.229025] Buffer I/O error on device sde1, logical block 6028472
[ 913.229030] lost page write due to I/O error on sde1
[ 913.229036] Buffer I/O error on device sde1, logical block 6028473
[ 913.229041] lost page write due to I/O error on sde1
[ 913.247302] sd 32:0:0:0: [sde] Unhandled error code
[ 913.247311] sd 32:0:0:0: [sde] Result: hostbyte=DID_NO_CONNECT driverbyte=DRIVER_OK
[ 913.247319] end_request: I/O error, dev sde, sector 6036656
[ 913.705069] usb 1-1: new high speed USB device using ehci_hcd and address 35
[ 913.839939] usb 1-1: configuration #1 chosen from 1 choice
[ 913.852073] scsi33 : SCSI emulation for USB Mass Storage devices
[ 913.852360] usb-storage: device found at 35
[ 913.852365] usb-storage: waiting for device to settle before scanning
[ 918.852238] usb-storage: device scan complete
[ 918.892589] scsi 33:0:0:0: Direct-Access USB DISK 2.0 PMAP PQ: 0 ANSI: 0 CCS
[ 918.894335] sd 33:0:0:0: Attached scsi generic sg2 type 0
[ 927.765051] sd 33:0:0:0: [sde] 31277056 512-byte logical blocks: (16.0 GB/14.9 GiB)
[ 927.765532] sd 33:0:0:0: [sde] Write Protect is off
[ 927.765539] sd 33:0:0:0: [sde] Mode Sense: 23 00 00 00
[ 927.765544] sd 33:0:0:0: [sde] Assuming drive cache: write through
[ 927.769048] sd 33:0:0:0: [sde] Assuming drive cache: write through
[ 927.769057] sde: sde1
[ 927.804904] sd 33:0:0:0: [sde] Assuming drive cache: write through
- Code:
# mount /dev/sdd1 /media/dd/
Did not find any restart pages in $LogFile and it was not empty.
The file system wasn't safely closed on Windows. Fixing.
root@ubuntu:~# ls /media/dd
ls: I/O Error
